sound problems
kayleighnewberry
sound problems
Post by kayleighnewberry »
when i thought it was going smoothly.
I have captured my video fine but when I play it back I have no sound as I am I new to all this and don't have any instructions, I don't know what to do? Do I have to record audio seperatly?
Any advise given would be great.
Thanks :lol:
Post by BrianCee »
Some more information would help us to help you,
what version of videostudio are you using, how did you connect your camera to your PC (exactly - what wires etc. from where to where) , what is the spec of your PC , what did you do - what properties did you set, etc. etc.
There are some very clever people on here but I don't think any of them are mind readers or have a crystal ball - - - please help us to help you by giving as much information as you can - don't worry about getting the techhnical terms right. just put it best you can.
kayleighnewberry
I am using videostudio. I have connected the audio wires(red & white coloured wires) to my laptop from the back of my VCR also connected is S-Video wire (yellow) from my VCR to the videostudio device.
Properties set MPEG -
Audio data rate 224kp
what i did was:
I strated to play the video pressed capture to record( I had sound then)
but know i doing thtough the video clips and no sound is coming out
Please tell if you need any more info!!
I'm really rubbish at explaing all this i know but I really appreciate the help :D
llama
Post by llama »
Check you volume control properties and see which volume meter is controling the playback audio. Once that is established, go to the volume properties and change from play control to record control and select the volume control that was being used for playback. This should help you out.
Post by Trevor Andrew »
make sure that your volume control properties, recording tab, point to Line -In
Right click the loud speaker icon on your desktop tool bar / open / options / properties / recording
