Anyone using a Contour Shuttle Pro 2 w/ Windows 7 & VS?
dalemccl
Post by dalemccl »
Does anyone have a Contour Shuttle Pro 2 working correctly with Windows 7 and VS?
Mine was functioning correctly with X2 Pro under Vista 64 bit. I have upgraded the OS to Windows 7 64-bit and forgot to save my Shuttle settings file so I had to set up all the buttons again. I installed the newest Shuttle driver and used its control panel to set up the buttons and wheels the way I remembered setting them up before. The buttons work as expected, but I can't get the jog and shuttle wheels to function properly. (I do have one of the buttons assigned to "tab" and I press it before using the jog or shuttle wheels, which is a trick I read about in this forum earlier in the year).
If anyone is using the Shuttle Pro 2 with VS under Win 7, please let me know the control panel settings you have set up to allow the inner jog ring to advance frame by frame while you turn it (and advance faster the further you turn it) and to allow the outer wheel to advance through the time line (and advance faster as you turn the wheel from minimum position to max position.)
Thanks!
Sony XR-500V, VS Pro X2
After about 140 views of your post, and no replies, it might be safe to say that no one has. I came close to picking one up, but other things took priority, and just forgot about it since.
dalemccl
Post by dalemccl »
Ron P. wrote:After about 140 views of your post, and no replies, it might be safe to say that no one has. I came close to picking one up, but other things took priority, and just forgot about it since.
Thanks Ron. I first learned about the Shuttle when it was mentioned by a couple people in this forum who were using it and liked it. It worked properly under Windows Vista.
Your reply serves as a reminder to me to e-mail Contour's support again. They haven't answered the first inquiry I sent them.
