VS X2 Has different Quicktime Codec list to Quicktime itself
craftycurate
Post by craftycurate »
I am trying to export a movie from VS X2 Pro using Quicktime H264 codec.
However, the list of codecs available from the Quicktime dialog within VS X2 is different (and older, by the looks of it) from the codec list available within Quicktime itself.
Is this a known issue? If so, how can I get VSX2 to export in Quicktime H264 format?
Richard
rguthrie
motherboard: MSI MAG B550 TOMAHAWK
processor: AMD Ryzen 9 5900X 120-Core Processor
ram: 64GB
Video Card: AMD Radeon RX6600 XT
Hard_Drive_Capacity: 2TB + 4TB
Monitor/Display Make & Model: ViewSonic
Post by rguthrie »
craftycurate,
So, if I understand you correctly, you own a licensed copy of Quicktime Pro that you can use to encode video? If so, then I believe I can help you get this set up properly so you can use the Quicktime H264 format.
SFC (Retired) Ronald Guthrie (aka Alt0S4x)
VS4SE/6-11.5+/X2-X10 Ultimate/2018-2023, Pinnacle Studio 25; Ultimate; MotionStudio 3D; PI11/PIX3;Corel PainterEssentials 4
Photoshop CS5; Audacity; SonicFire Pro 6.0
Wacom Bamboo Fun Tablet
Canon Rebel T4i
craftycurate
Hi Ronald
Yes, I have a Quicktime Pro license, with v7.6.4 installed.
If you know how to use QT H264 within VS X2 Pro that woudl be very helpful!
Richard
rguthrie
ram: 64GB
Post by rguthrie »
craftycurate,
Cool! I posted a tutorial on encoding in mpeg4 using XVID. If you'll follow along with that tutorial, you should be able to use your QuickTime Pro encoder. Essentially, you're going to use the Make Movie Templates Manager to create a new encoding template. Now since I don't have Quicktime Pro, I'm just unsure as to whether you will need to choose AVI for the file format (like I did) or choose .mp4, or .mov. You'll need to see where the QuickTime encoder is hiding. My tutorial is at http://forum.corel.com/EN/viewtopic.php ... 742045e794 and included many screenshots.
I sincerely hope this helps, and if you have further questions, just ask!
Canon Rebel T4i
craftycurate
Thanks, but this doesn't address the original issue.
I can easily create a Quicktime profile in VS, but it offers different QT codecs to those on offer in QT itself.
rguthrie
ram: 64GB
Post by rguthrie »
craftycurate,
Ca I ask what the specific "specs" are that you're looking for? In other words, what is QuickTime offering that VS doesn't apparently do?
Canon Rebel T4i
