Can you work with FLV videos in Video Studio X2 Pro?
Hooterville
Post by Hooterville »
Tried to open a couple and it says not supported.
Is there a trick to work with FLV in Video Studio X2 Pro?
Thanks.
VS only Exports/Creates FLV files, it does not support editing them. To edit FLV files, you need a Flash Authoring program that also supports Flash Video. About the only one that I'm aware of that does, is Adobe Flash.
However something that I just discovered is if you have a FLV player installed, you can right-click on an FLV file in your video library, and select Play Streaming Clip, and it will open your FLV player and play the FLV file..
Also noted is that VS will insert an FLV file into a Video Library, but it refuses to insert it to a video track, thus you can not edit them...
mitchell65
motherboard: Dell Inc. 04GJJT A00
processor: 2.80 gigahertz AMD Athlon II X4 630 Quad Core
ram: 4Gb
Video Card: ATI Radeon HD 4200
Hard_Drive_Capacity: 560Gb Sata
Re: Can you work with FLV videos in Video Studio X2 Pro?
Post by mitchell65 »
Hooterville wrote:Tried to open a couple and it says not supported.
Thanks.
Most video converters including the freebies will convert an FLV to numerous formats that you can edit in VS. You can then if you wish export them back to FLV in VS via Share > Create Video File > FLV
John Mitchell
Hooterville
OK, Thanks for the replies.
What is the best free converter?
mitchell65
ram: 4Gb
Super seems to be one of the more favoured ones on this Forum, see here:
http://www.erightsoft.com/SUPER.html
John Mitchell
Post by Trevor Andrew »
I had assumed that X2 was capable of editing flash flies, a little disappointed to find it will only convert to flash.
Try a program called Super a link from the forums Free Stuff
http://forum.corel.com/EN/viewtopic.php?t=12931
I¡¦ve been giving these a try, seem very good, not expensive
http://avs4you.com/
craftycurate
Post by craftycurate »
Why is "FLV" listed as a fule type in the Add Video dialog since importing seems not to work?
mitchell65
ram: 4Gb
craftycurate wrote:Why is "FLV" listed as a fule type in the Add Video dialog since importing seems not to work?
Ask Corel :wink:
John Mitchell
