To insert image "GIF"
paulinho
Post by paulinho »
I have an image with extension "JPG."
I would like to insert in this image an object in movement with extension "GIF."
With SW Ulead PhotoImpact 10.0 is possible?
In case it is not possible which SW that has this possibility?
Paulinho
Masami
Post by Masami »
PI10 can do that easily (pretty much any photo editing SW can) Just open the file and then go to file -> save as. Then under "save as type" select GIF
paulinho
Animation GIF
Post by paulinho »
Masami, didn't work.
I opened a file with extension "JPG" and I inserted in this file an illustration "GIF" in this same file.
Then and I saved with extension "GIF."
When I opened the save file the object that I inserted was not in movement.
Thanks Paulinho
MikeGunter
Post by MikeGunter »
A jpeg file can have 16.7 million colors, a gif file only 256. So there are less colors in gif and less flexibility in how you use it.
You also suggest *motion* such as one can get in an animated gif using the Gif Animator that is part of PI10.
You'll have to add frames for the animation to work.
Mike
Masami
Post by Masami »
Sorry, I missed th emotion part.
IF you want to make a motion (or animated) gif, then use the gif animator that came with it.
MikeGunter
Masami wrote:Sorry, I missed th emotion part.
I'm not sure he meant motion, either. That would require frames of different content, something one couldn't expect to save a jpeg and have an animated gif file.
Dunno...:?:
Mike
