VS12: FrameServer not working for 16:9 Project
mtubesing
Post by mtubesing »
I have used DebugMode Frameserver for earlier versions of VS so that I can encode using x264. I have the FrameServer software correctly installed in the vio folder and I can write the signpost AVI, but similar to this post:
http://forum.corel.com/EN/viewtopic.php?t=36492
The output is distorted and it seems like VS thinks it should be rendering in 4:3 mode, even if I select a User Defined 16:9 resolution when I write the signpost AVI. Any thoughts or suggestions?
The other option is to encode using ffdshow, but that won't allow me to frameserve to AviSynth, which I normally do for some pre-encode filtering and cleanup.
Thanks for your help.
Welcome to the forums, (belated at that)..:oops:
I've only used DebugMode's Wax and Wink, not the Frame Server. Due to the lack of replies, I suspect that we don't have any regulars that have.
Most of the time, even if you have the project settings to 16:9, if the actual video clip(s) are 4:3 VS will render using the aspect ratio of the video clip. Are you using Smart Render?
Have you inquired on DebugMode's Frame Server Google Groups ? Satish has migrated from using his forum to Google groups, for questions and discussions.
