Code: Select all
Format : f4v
Codec ID : f4v
File size : 110 MiB
Duration : 15mn 1s
Overall bit rate : 1 021 Kbps
Encoded date : UTC 2009-05-17 14:15:32
Tagged date : UTC 2009-05-17 14:15:32
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 15mn 0s
Bit rate mode : Variable
Bit rate : 901 Kbps
Width : 854 pixels
Height : 480 pixels
Display aspect ratio : 16/9
Frame rate : 23.976 fps
Standard : NTSC
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.092
Stream size : 96.8 MiB (88%)
Title : MainConcept
Language : English
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Duration : 15mn 1s
Bit rate mode : Constant
Bit rate : 112 Kbps
Channel(s) : 2 channels
Channel positions : L R
Sampling rate : 44.1 KHz
Resolution : 16 bits
Stream size : 12.0 MiB (11%)
Language : English
Thanks,
ABe.
