Overlapping Menu objests VS 11+
Ken Veal
- motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
- processor: 360 gigahertz Intel Core i9 900K
- ram: 32 GB
- Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
- Hard_Drive_Capacity: 1250GB SSD
- Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
- Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
When customising menu objects to alter the shape on the menus a message displayed saying (and it showed) that there was an overlap on one of them and did I want to continue.The selected template had one more object than the no of chapters I had added before.I continued but the result seemed ok.What was all that about...............Ken
Hi Ken
The menu objects are areas/hotspots on screen that are selected to play a particular piece, title/chapter.
If you have them overlapping, then it may try to play two at once, very confusing, the menu structure probably just wont work correctly.
Fortunately your setup worked, maybe one of the overlapping objects were not required, I just don¡¦t know.
I would have re-made the menu to correct the problem. Sometimes a little difficult to do.
When constructing the menu and changing those objects, when you have one selected you will normally see a dotted-line frame surrounding it -- sometimes a surprising distance out from it. This in effect is the area in which that button or title is 'active'. As Trevor says, if you have these active areas overlapping, sometimes, depending on the actual button, there could be a conflict. So you just need to be aware of the limits of the dotted frames around the other objects on the menu...
Ken Veal
- ram: 32 GB
overlapping
Thanks for the replies.Just to clarify, the chapter thumbnail in question
was part of a default menu template choice and not one which I had made up
Ken Veal
- ram: 32 GB
- ram: 2 GB
- sound_card: Intel GMA 950
The various menu "objects" - buttons, frames, highlight images and text
can be various shapes and sizes, however the "Hotspot" is always a solid
square/rectangle shape with the object concerned contained within it- this is why they are reported as overlapping even though they might visually appear to be apart.
Ken Veal
- ram: 32 GB
Ken Veal
- ram: 32 GB
