VLC has hijacked my VS files
Ken Veal
motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
processor: 360 gigahertz Intel Core i9 900K
ram: 32 GB
Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
Hard_Drive_Capacity: 1250GB SSD
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Post by Ken Veal »
VS11+ XP Home.
Since downloading VLC media player it has taken over all my VS files in my working folder.I have to right click and "open with" VS.How can I get back to the previous situation where I just clicked on them and they opened in VS.....................Ken
skier-hughes
Microsoft MVP
motherboard: gigabyte
ram: 4GB
sound_card: onboard
Hard_Drive_Capacity: 36GB 2TB
Post by skier-hughes »
right click file
open with
choose programme
"select VS"
always use this programme
Ken Veal
ram: 32 GB
Post by Ken Veal »
Thanks Graham
That worked OK for the first fille I used it on.Do I have to do this for every file.Is there a way to "batch" this command.When I clicked on another file (that I had not done what you advised to it) it still wanted to play in VLC after a "AVI index box" showed with the following in it:-
This AVI file is broken,seeking it will not work correctly.Do you want to try and fix it.It may take a long time.I did not try then it opened in VLC.
I opened it in VS and it played ok........................Ken
skier-hughes
Microsoft MVP
ram: 4GB
sound_card: onboard
you need to do it for each file type.
Quicker might be to use system restore and go back to before VLC, then re-install VLC but don't allow it to make any associations to file type.
Ken Veal
ram: 32 GB
Post by Ken Veal »
Would this problem go away completely if I just uninstalled VLC and forget about using it because I only really installed as an easy way to play CDs on the PC
I wouldn't. I would do it Graham's way, once you have opened each affected file type once you should be "back to normal". there can't be that many file types affected.
