This is the BD5 or BD9 route? The same as AVCHD? What about bitrate and playing time?Same format as AVCHD which is a hybrid.
To burn that type of disc I presume I need nero 9?
No any software that will burn a data DVD will/should work! It will produce a full BluRAy folder structure within the BDMV folder. Just select the Folder BDMV and burn that as data to a DVD disc. You do of course need a BlyRay player to play it but you can open the BDMV folder on your PC, than go to the Stream Folder and in there you will see the M2ts files. These will play in you PC player or they do in WinDVD9 and AVS Media Player and Windows Media Player. This is where you can check your video before burning to a DVD. This method burns to a disc very quickly as there is no rendering it is a straight data transfer.Henny wrote: To burn that type of disc I presume I need nero 9?
I have just checked one of my "Stream" files (MTS) and that held the UFF that I set it to. My original clip was UFF. I set the burn to 1440 x 1080 as I read somewhere that this was the standard but my camera saves to 1920 x 1080. I might try that later to see if it works on my NEW BLU-RAY PLAYER THAT WILL ARRIVE TOMORROW ( I hope)Ken Berry wrote:I also remain a bit mystified by the fact that though I thought I had reset the burn properties to Upper Field First to match my HDV, the resulting file is LFF.
Mitchell, I hope it does and if so, enjoy it!NEW BLU-RAY PLAYER THAT WILL ARRIVE TOMORROW
So, Mitchell65, not the 'CERTIFICATE' folder?mitchell65 wrote: Just select the Folder BDMV and burn that as data to a DVD disc.
No it is empty anyway!Henny wrote:So, Mitchell65, not the 'CERTIFICATE' folder?
