Smooth fade out of music
Hi all,
I want to fade out music in a clip gradually. I have clicked on the music track in the audio file and then draggred the volume down slowly. When I play the music it cuts off abruptly at the end.
What is the easiest way of gradully fading out a music clip smoothly?
Rob
Rob
Hi Rob
I find ¡¥Rubber banding¡¦ dragging the volume level down a bit awkward to use.
Dragging the last frame seems to be difficult.
From the edit timeline view, select the clip, hit the fade fade-in or Fade ¡Vout ramps adjacent to the digital clock.
The default fade duration can be set from File ¡V Preferences.
Switch to Audio view to see results,
What version of Vs are you using?
Oh by the way, view the effect in project playback mode.
Hi Rob
You apply a fade-in/out to individual clips, the length of the fade can be set in preferences, this will affect all newly applied fades. Once you have applied fade out, go to the Audio view, you can manually change the fade duration by dragging the square at the top of the ramp.
Use the timeline Zoom option to expand/contract the timeline(the + and ¡V slider)
When editing the audio in VS, you have the solid line 'rubber band' along which you can insert nodules (or 'square' dots) at selected points. You can then drag one of those 'squares' up or down to vary the volume at that point.
In a fade in or out, the rubber band line starts or ends down at zero and there is an angle (or 'ramp') in the line leading up from or down to zero. It will then hit a square where it flattens out. If you want to lengthen or shorten the fade-in or out, then you click and hold the square and drag it either right or left.
Ken Veal
- motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
- processor: 360 gigahertz Intel Core i9 900K
- ram: 32 GB
- Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
- Hard_Drive_Capacity: 1250GB SSD
- Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
- Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Rubber Band
This is Ken Bs essay on rubber banding
http://phpbb.ulead.com.tw/EN/viewtopic. ... ubber+band ......................Ken
Ken Veal
- ram: 32 GB
Rubber band
So you cant remember all of your 9187 posts Ken, sorry but this just wont do
Essay? That was approaching novel status.
Jeff
Dentler's Dog Training, LLC
Ken Veal
- ram: 32 GB
Jeff
