can i save wav files??
marcasp
Post by marcasp »
Hi folks you did so good Im back with another dumb question.
Is there some way or some folder that I can save wav files so they
will appear in the library when I click AUDIO ...
I found the folder in corel samples but when I put a wav file in the folder it did not show in the library
using vs 12 and xp...
Thank you for any help...
Bob
When you refer to the library, do you mean the video library, which only holds video and image files? Or do you mean the Audio Library window, which obviously only holds audio files, including .wav files? That window should open when you click the Audio tab, and the icons should be black and white speaker symbols with a musical double note over it. If I right click in that window and select Insert Audio, then navigate to the file I want to include, it then appears as a new icon in that library window.
As to your specific question, you can create a .wav file from a video file by putting the latter in the timeline, then choosing Share > Create Sound File. You specify .wav as the output format, give it a name and specify where it is to be stored. Then click Save. The new file is created in the designated folder, but importantly, a new icon with the name you gave the file, appears in the Audio library window.
marcasp
Post by marcasp »
Thank you much I will try this
Bob
Clevo
motherboard: Asus PK5
ram: 4GB
Hard_Drive_Capacity: 850GB
Post by Clevo »
...and for .wave files or any audio files you click on Library manager, then browse to where your file is, click Open and an icon will appear in your Library.
Post by Trevor Andrew »
Or
Use Windows Explorer to locate your files, then drag and drop then to the library.
