VideoStudio 12 trial and mp4
mgrogan
motherboard: ASUSTeK COMPUTER INC. P8B75-M Rev X.0x
processor: 3.60 gigahertz Intel Core i75-4790
Video Card: NVIDIA GeForce GTX 650 Ti BOOST
sound_card: NVIDIA S27C350-4
Hard_Drive_Capacity: 2 TB
Monitor/Display Make & Model: Samsung 27" Series 3 LED MSC350_S27C350H
Corel programs: VideoStudio Ultimate 2019
Post by mgrogan »
Hello,
I'm trialling the software 12.0.98.0 Pro to determine if it will allow me to edit my .mp4 files from my el eheapo Opek IDV 5550i (from catchoftheday.com.au).
If I insert video I get the error message "File format mismatch".
I tried to update the patch
http://www.corel.com/servlet/Satellite/ ... 9440480826
as it was mentioned that "MP4 file insertion now works as expected "
but when I try to install the VSX2PROPATCH.exe patch I get the error message "Installer cannot find Corel Video Studio 12 on your machine".
This is an obvious message as I'm not a registered user.
I tried using both the settings 1440 x 1080 and 640 x 480 on the camera.
How can I test my .mp4 file with the software?
Pardon my ignorance but are there different versions of .mp4 if, so how to determine what I have?
I have updated Microsoft® Windows Media® Player, Apple® QuickTime®, RealNetworks® RealPlayer and Microsoft® DirectX®
as mentioned here
http://www.corel.com/servlet/Satellite/ ... bview=tab6
The programs VLC, Windows Media Player, RealPlayer and Quicktime allow me to view the .mp4 file. I'm assuming that I have the codecs? installed for .mp4?
I have tried the software on an XP machine in case it was a compatability issue of windows 7, but had the same result "File format mismatch".
Many thanks
Margaret
sj1805
System_Drive: E
Post by sj1805 »
You cannot apply updates or patches to trial versions.
[img]http://www.steve-jones.pwp.blueyonder.co.uk/sjjsig09.png[/img]
mgrogan
Post by mgrogan »
sj1805 wrote:You cannot apply updates or patches to trial versions.
Thanks for that.
Does the patch mean that would be able to edit my .mp4 file?
Margaret
Yes that patch should fix the mp4 insertion problem.
mgrogan
Post by mgrogan »
vidoman wrote:Yes that patch should fix the mp4 insertion problem.
Thanks for your reply.
I did order and eventually successfully activated the product.
http://forum.corel.com/EN/viewtopic.php?p=187709#187709
Unfortunately the purchased product with update version "12.0.98.1" does *not* allow me to edit my .mp4 files.
I get the error messge of Invalid format still.
A most, most frustrating 4 hours.
Margaret
PS. I do appreciate having this forum.
mitchell65
motherboard: Dell Inc. 04GJJT A00
processor: 2.80 gigahertz AMD Athlon II X4 630 Quad Core
ram: 4Gb
Video Card: ATI Radeon HD 4200
Hard_Drive_Capacity: 560Gb Sata
Post by mitchell65 »
Hi Margaret
For what it is worth, I downloaded an mp4 file from YouTube. It plays in WinDVD9 OK but when I try to import into VS x2 Pro it crashes and I get the VS has got to close etc. Will keep plugging away at this one!
John Mitchell
mitchell65
ram: 4Gb
Have now emailed Corel support and asked if this prog supports MP4 files. There is by the way nothing wrong with the MP4 file I downloaded from YouTube. I can open it and edit it in an alternative, much simpler Video Editor that I use.
Will keep you posted when I hear from Corel.
John Mitchell
I've had problems with some mp4 files. I ran them through Super a free conversion utility. I kept everything the same, and was able to insert the video file created by Super into VS. Might be worth trying.
jameshorsley1976
Post by jameshorsley1976 »
Do not use mp4s a lot but have tried 8-10 and all have worked.
mitchell65
ram: 4Gb
I have just done the same as vidoman although not with SUPER andit worked! So definitely worth a try.
John Mitchell
mgrogan
Post by mgrogan »
Thank you everyone.
SUPER was unable to read the file.
This is the analysys from Super
SUPER © v2009.build.36 (June 10, 2009)
Multimedia Analysis Box by http://mediainfo.sourceforge.net
Detailed Analysis of: keyboard.MP4
General Complete name : C:\Users\mgt-vista\Videos\keyboard.MP4
Format : MPEG-4
Format profile : JVT
Codec ID : avc1
File size : 11.3 MiB
Duration : 11s 444ms
Overall bit rate : 8 263 Kbps
Encoded date : UTC 2009-11-16 06:37:11
Tagged date : UTC 2009-11-16 06:37:11
AMBA :
Video ID : 1
Format : AVC
Format/Info : Advanced Video Codec
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate mode : Variable
Width : 1 440 pixels
Height : 1 080 pixels
Display aspect ratio : 16/9
Frame rate mode : Constant
Frame rate : 29.970 fps
Bits/(Pixel*Frame) : 0.000
Stream size : 11.0 MiB (98%)
Title : Ambarella AVC
Audio ID : 2
Format : AAC
Format/Info : Advanced Audio Codec
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Duration : 11s 370ms
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Channel positions : L R
Sampling rate : 48.0 KHz
Resolution : 16 bits
Stream size : 178 KiB (2%)
Title : Ambarella AAC
I smiled when I read what SUPER could do. All I require of movie editing in the short term is to join some of my .mp4 files. :) :(
Margaret
mgrogan
Post by mgrogan »
mitchell65 wrote:Have now emailed Corel support and asked if this prog supports MP4 files. There is by the way nothing wrong with the MP4 file I downloaded from YouTube. I can open it and edit it in an alternative, much simpler Video Editor that I use.
I look forward to your reply. I bought VS 12 Pro in good faith having attempted their trial though it did not allow updates. The software currently is very unsuitable for my purposes.
Margaret
Try Super
This piece of software converts almost any video format into almost any other video format. Very useful if you've downloaded DivX Xvid or MPEG4 files off the internet and then find you are having difficulty editing them due to their highly compressed nature.
http://www.erightsoft.com/SUPER.html
Steve,
She did try Super, as I recommended above, however Super did not help. I think she has a AVCHD file (Advanced Video Codec-Hi Definition).
mgrogan
Post by mgrogan »
vidoman wrote:Steve,
Thanks Steve. How responsive have Ulead and Corel been to updating the software for new/newish file types?
Margaret
