Problem including photos into my video project.
I know this subject has been covered in these forums before and I have read them but one thing I don't understand is why Windows Movie Maker is able to handle jpgs without any problems and U lead 11 plus can't.
I compleated the photo montage using WMM and imported it into Ulead so I could add menus and the whole thing is lousy.
I can't believe I would have to go back and convert all my jpgs to Bitmaps to get the quality I had in WMM which some of the answers to this problem on this forum suggests.
I hate to rant but I am finding out that WMM is a free, wonderful, easy program that only lacks a few more features and a menu making capability that would blow all these other high priced editing programs out of the water when it comes to making simple family videos with a photo montage. We're not talking Martin Scorsese quality films here.
The jpgs are 76 dpi and 604 x 453 around 820,000 bytes.
Again, I don't understand why Windows Movie Maker is able to handle jpgs and video without any problems and U lead 11 plus can't or another high priced competator program I own.
Any suggestions would be appreciated to this newbie. Thanks for hearing me out.
- ram: 2 GB
- sound_card: Intel GMA 950
There would appear to be a problem with either your computer or your installation. VideoStudio does accept JPG images. I would though advise you to resize them because 604 x 453 is not a normal video size.
Please view:
What dimensions etc should I use for still images in Videos?
I would also advise you to click here -->
so that we can then view your system specifications.
Please view:
Thanks for the quick reply. Short of resizing 50+ photos one by one, is there a way or a program that would resize them all at once?
Yes, I have a Corel photopaint program and there is a setting for recordings and scripts that does exactly that. Thank You. I never needed or used it before.
My only comment is that to resize to 720 x 480, I have to have the box marked 'maintain aspect ratio' unchecked. This leaves the photos with a skewed look. Any thoughts?
- ram: 2 GB
If you think about it, even using WMM they are going to get skewed because they are going to get stretched one way or the other to fit your TV screen.
I know it is time saving to automatically adjust them all as a job lot but best results will obviously be to go through them and crop them manually to the correct dimensions - avoids losing heads and feet etc.
What I would do is firstly use a macro to resize them so that they are at least
720 and at least 480 (one of those will be larger when you maintain the aspect ratio). Then I would go through them and crop off the excess - choosing the are I want to keep rather than leaving it to the discretion of the computer.
Alternatively and perhaps better is to resize then as I suggested, but rather than now go through and crop them - use the pan and zoom filter or the crop filter and create a Ken Burns effect - brings your photographs to life.
MediaStudio/VideoStudio: Create a Ken Burns effect Slideshow
- aljimenez
- motherboard: Dell Inc. A08 4.16.2014
- processor: IntelCore i7-4790 3.60GHz 4Cores 8 Logical Proc
- ram: 24GB
- sound_card: AMD High Definition Audio
- Hard_Drive_Capacity: 500SSD+2TB
- Monitor/Display Make & Model: Three monitors, all Dell brand, one 4K
- Corel programs: Visual Studio, Paintshop
Re: Problem including photos into my video project.
The best freeware image viewer:corelito wrote:Thanks for the quick reply. Short of resizing 50+ photos one by one, is there a way or a program that would resize them all at once?
http://www.irfanview.com/
It has a batch program I use that renames and/or resizes photo files fast.
User for more than 10 years.
Your images are 604 x 453 at a ratio of 4:3corelito wrote:Yes, I have a Corel photopaint program and there is a setting for recordings and scripts that does exactly that. Thank You. I never needed or used it before.
720 x 480 is not 4 x 3.
Try using 720 x 540, this should keep your images in proportion and fill the screen.
OK
Increasing the size will not improve the quality, your images at 604 x 453 are small to say the least, unfortunately to fit the video screen you have to resize them. I generally use images twice the size of the video frame, for NTSC this would be 1440 x 1080px, this allows for some Pan & Zoom type editing.
Furthermore if you use the zoom function as part of VS editing the quality will deter ate further.
Its difficult to compare image quality on a pc monitor as the monitor only displays 96 dpi.
skier-hughes
- Microsoft MVP
- motherboard: gigabyte
- ram: 4GB
- sound_card: onboard
Thanks for the tip!aljimenez wrote:The best freeware image viewer:corelito wrote:Thanks for the quick reply. Short of resizing 50+ photos one by one, is there a way or a program that would resize them all at once?
- ram: 2 GB
If you have Windows XP
Please click here -->
Then you can also batch resize all the pictures in a hard drive folder using a Windows Powertoy Image Re-sizer
