I don't understand. Why not just use the Mute button?mitchell65 wrote:There's always two ways etc etc.
Here's my solution. Open the clip. Go to Audio View and use the rubber band to reduce the volumn to the lowest level (vitually muting it ) of the unwanted part of the audio. No need to split the audio at all. Also has the anvantage that if you need to adjust it is so easy to do so later without any sync problems.
Split Audio for one clip
Jeff
Dentler's Dog Training, LLC
mitchell65
- ram: 4Gb
Then that would have muted the entire clip. I understood that it was only parts of the clip that needed the audio muted.Black Lab wrote:I don't understand. Why not just use the Mute button?mitchell65 wrote:There's always two ways etc etc.
John Mitchell
I didn't get that impression from anything he said.
Jeff
Ken Veal
- motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
- processor: 360 gigahertz Intel Core i9 900K
- ram: 32 GB
- Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
- Hard_Drive_Capacity: 1250GB SSD
- Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
- Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
What was needed
To clarify
I wanted to put all the audio from the entire clip in another part of the project.With that done I then could edit the original clip as desired
via multi trim thereby cutting out parts of the clip I did not want to show.
..............Ken
..............Ken
mitchell65
- ram: 4Gb
Clevo
- motherboard: Asus PK5
- processor: Intel Quad CPU Q6600 2.40GHz
- ram: 4GB
- Video Card: NVIDIA GeForce 8600 GTS
- sound_card: Auzentech X-Fi Forte
- Hard_Drive_Capacity: 850GB
Re: What was needed
If I read you right...are you not then setting yourself up for sync issues when matching the entire audio with the cut up video?Kenneth Veal wrote:To clarify
..............Ken
Ken Veal
- ram: 32 GB
audio split
This is what I was doing-I filmed some dancers in a Madeira Hotel.I filmed all they did, several different folklore songs and dancing.I then split the audio from that to use after the intro at the start of the project.Then I went back to the clip of the video which was inserted later on in the project and edited the video by cutting out some parts of it of (with the audio intact and cut at the same point as the video)This was to avoid it being too boring, just watching dancing for too long..................Ken
