Field Order -- Frame based, LFF, UFF?
erdna
motherboard: Gigsbyte H81M
processor: I7 4770
ram: 16GB DDR3
Video Card: Intel HD4600
sound_card: Intel display audio
Hard_Drive_Capacity: 1TB 7200rp
Monitor/Display Make & Model: Panasonic TX32cx600e
Post by erdna »
The camcorder is a Sony XR500. It doesn't have a progressive mode setting. I even checked my UFF and LFF SD DVD's using a TBC which enables me to freeze any frame, and within this frame, I can select field 1 or field 2. I can clearly see two different fields in the frame freeze, with the known interlace artifacts on the moving objects, also the two fields (with the field1/2 TBC selection) are clearly not taken at the same time. My understanding is, that (as long as nobody else has another explanation) that the information about the field order (in the mpeg video info header) is interpreted and used for all interfield codecs (HDV and AVCHD), and overrides whatever setting is being selected in an NLE.
