Field Order -- Frame based, LFF, UFF?
woodchuck
motherboard: PEGATRON Corporation 2AC31.04
processor: 2.80 gigahertz Intel Core i7-2600S
ram: 8.2 gb
Video Card: AMD Radeon HD 6550A
sound_card: AMD HD Audio
Hard_Drive_Capacity: 1 Tb
Monitor/Display Make & Model: Generic PnP Monitor
Post by woodchuck »
I believe someone posted a simple explanation of frame based, lower field first, upper field first but I can't seem to find it. Could someone explain these terms and which to use in various situations?
I have been using Frame Based for photos but I'm not sure what is best for DVD's when I have video and photos.
Thanks for any suggestions.
Post by Black Lab »
For the detailed definition read here: http://www.dvmp.co.uk/digital-video.htm
For video you should use whatever the field order is for your source video. Mini-DV is Lower Field First, DVD cams use Upper Field First.
A common misconception is that Field Order is determined according to the final output - such as I am going to put this on a DVD, or I am going to put this on the internet.
That is wrong, Field order is determined by the source of the video.
With a few exceptions the general rule is that stuff from a digital source is lower field first, stuff from an analogue source is upper field first, Stuff from a scanner or drawn with a graphics program are frame based.
Many High Definition camcorders record in a high bit rate MPEG2 or MPEG4 and these are often upper field first.
Xyzzy2
motherboard: MSI Z77MA-G45
processor: Intel i5-3570K
ram: 8 GB
Video Card: MSI R7770-2PMD1GD5 OC
sound_card: Realtek 892
Hard_Drive_Capacity: 6.25 TB
Monitor/Display Make & Model: HP ZR24w
Post by Xyzzy2 »
sjj1805 wrote: With a few exceptions the general rule is that stuff from a digital source is lower field first, stuff from an analogue source is upper field first.
Are you sure not the other way round, or at least not always? My DV is LFF and AVCHD is UFF.
Post by Trevor Andrew »
Yes that is correct.
Digital source such as Dv-Avi uses Lower Field (Mini DV type camcorder Hi8 etc)
Analogue capture generally uses Upper Field (VHS-TV tuner Etc)
Newer types of video, High Definition although digital uses Upper Field or frame based
The general rule was clear until HD was developed.
Xyzzy2 wrote:Are you sure not the other way round, or at least not always? My DV is LFF and AVCHD is UFF.
Read it again - you have repeated what I said.
woodchuck
ram: 8.2 gb
Post by woodchuck »
Thanks, Jeff, for pointing me to the excellent article on DV and field order. It gives me a better understanding of the differences in LFF and UFF.
Also, thanks to Steve and the other posters for summarizing what field order to use based on the source. Since I'm not into HD (yet), I've been using LFF with good success. My Sony DV camcorder outputs DVI and most of the other clips I use are AVI. I have been receiving a free motion loop weekly from motionloops.com for over 2 years and they are AVI.
Thanks again, you are the best!
Joyce
Xyzzy2
ram: 8 GB
Post by Xyzzy2 »
AVCHD is analogue?
Post by Black Lab »
sjj1805 wrote:Many High Definition camcorders record in a high bit rate MPEG2 or MPEG4 and these are often upper field first.
AVCHD is MPEG4.
AVCHD is analogue?
No
AVCHD is digital
Go back a few years, before HD High Deffinition.
We had Digital and Analogue
Digital Lower Field, Analogue Upper Field
Now introduce HD (High Definition----AVCHD)
This uses Upper Field
Although some HD may use Frame Based.
The old digital Dv-Avi uses Lower
the new digital HD uses Upper
Confused now
sjj1805 wrote: With a few exceptions the general rule is that stuff from a digital source is lower field first, stuff from an analogue source is upper field first, Stuff from a scanner or drawn with a graphics program are frame based.
erdna
motherboard: Gigsbyte H81M
processor: I7 4770
ram: 16GB DDR3
Video Card: Intel HD4600
sound_card: Intel display audio
Hard_Drive_Capacity: 1TB 7200rp
Monitor/Display Make & Model: Panasonic TX32cx600e
Post by erdna »
sjj1805 wrote:A common misconception is that Field Order is determined according to the final output - such as I am going to put this on a DVD, or I am going to put this on the internet.
Does this also mean, that whatever is being set e.g. in the burning module (LFF,UFF) it is being overruled by the source field order?
Post by Black Lab »
NO. The source doesn't override anything. You have to SET IT to whatever the source is.
erdna
processor: I7 4770
ram: 16GB DDR3
Post by erdna »
To me, this is not what sjj1805 wrote...moreover on june 10 2009 I posted in this forum that I experienced NO difference in image quality when burning a DVD out of AVCHD 1080i footage, whatever the field order setting in the burning module was. I experienced exactly the same results today when making a DVD with UFF and another with LFF setting. The DVD contained fast motion , but no difference on PC display, no difference on dvd player-analog monitor, no difference on a DVD player-50" plasma display.
Although you indicate 1080i.
Was the original video actually Upper Field (Interlaced) or Frame based. (Progressive)
You would be able to render progressive to interlaced using any field order, upper or lower with the same results.
If it works for you then that¡¦s good, I do not use HD so cannot check quality of these types of videos.
But if you do have quality problems then the first check would be the field orders.
