Every time I close VS x2pro, after it closes down, I get a message " Corel VideoStudio encountered a problem and needs to close...
Any ideas where to look. Otherwise it works 100%
Stelios
VS encountered a problem
That "problem" has been around for a few versions now. Nobody really seems to know what causes it. But as Mr. B states it is really not a problem as it doesn't seem to negatively affect anything. Therefore it is recommended that you simply ignore the message.
If you should get a message upon restart asking to recover the previous project I always answer "no" because I saved my project when I closed down.
Jeff
Dentler's Dog Training, LLC
dbz2000
- processor: InTel[R] Core [TM] i9 7900X 3.60 Ghz
- ram: 16 GB
- Video Card: GTX 1070
- sound_card: NVIDIA High Definition Audio Device
- Hard_Drive_Capacity: 1.5 TB
- Monitor/Display Make & Model: Dell ST 2310 Analog
- Corel programs: VideoStudio 2018_ VideoStudio Paintshop
I only started to encounter this message in VS Pro 12. What I do is clear the timeline after I save the project I am working on and then click on New Project before closing down and that seems to void that message. I have no rational reason why this works for me and it may not work for others, but I too, have found that the close down message doesn't affect my using the program. So I just live with it or do as described above. Take care!
DBZ
DBZ
"Instead of trying to add years to your life; try adding life to your years"
- ram: 2 GB
- sound_card: Intel GMA 950
I don't get the shut down error - but I don't have that VS pre-load running either. One of my pet hates are programs that install things in the windows Registry start up locationsClevo wrote:My guesstimation is the VS pre-load. When you look at Task managaer just after you first start your PC a small VS pre-load file is in the Start-up.
I think it's meant to help with VS loading faster.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
and
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run
I regularly inspect and remove entries from there that I don't want running in the background. If you find an entry in the Registry start up locations then
Google it and establish what it is and what it does.
Remember - Messing with the windows registry can be dangerous if you do not know what it is you are doing and how to recover from a mistake. If you make a mess of the registry you could end up having to re-install Windows.
