Chris, naturally...I've explained that in an earlier reply. That's not the problem, not with a final ISO that works containing mixed ratios. The problem is with mixed ratios that doesn't work as I've repeatedly explained here.chrish wrote:Hi
I am a bit lost for any more suggestions What you are trying to do I don't think is possible
If you say the ISO file works OK Try burning this to a Disc using the burn function in tools
It has just happened AGAIN...I had a new project with mixed ratios (one was 4x3 and two were 16x9). I had preconverted the two 16x9 videos and imported them into DMF and saved the project, which was set for 16x9. I later preconverted and imported a third video which was 4x3...and my final ISO/DVD turned out EXACTLY as I wanted it when I watched it on my tv (as well as how the video VOB files were on the disc): the 16x9 videos were as they should be, and the 4x3 video was as it should be.
Explain why this happens sometimes and not others.
