I'm trying the trial version of UVS9. Hey they put File etc. back on the left where it should have been from the beginning of time! Other than the fact that the help system only tells the name of the functions without any instruction as to what to do with them (just a hint, please?) {Sort of like: This is the clutch, this is the brake this is the transmission - now you drive it}The help still needs to be able to stay on top of the program. How hard can this be to include in the program? Also the same guy that wanted to improve Widows stock operating procedures by hiding and then misplacing File, etc. must be in charge of not allowing you to access the standard tool bar at the bottom of the screen so that when Help does disappear you can get it back.
Actually I hope I'm wrong and someone will inform me that: 1. there is a way to do this. 2. ts obvious and 3. I am a Dumb A... for not discovering it on my own.
Sean
Help with Help
Tool bar
Press the Windows button on your key board
Or
Change the screen resolution higher than 1024 x 768, but you may need a larger monitor.
I have just replaced my monitor and am now seeing the complete toolbar whilst running Video Studio.
19inch Hanson 900p
Although the help screen does minimise when you use VS it is accessible as you can see the toolbar.
Tool bar
Or
19inch Hanson 900p
