rendering
classicwest
rendering
I have MFP7. I have edited a movie in Canopus and rendered it to MPG2, I bring the movie into MFP7 and render it again to MPG2. Does this compress the movie further?
I do it this way as if I don't render it again in MFP7, the slow motion on my footage becomes jurky
Allan
Allan
skier-hughes
- Microsoft MVP
- motherboard: gigabyte
- ram: 4GB
- sound_card: onboard
Mpeg is a lossy format, so each time you save it and render it it will use the mpeg compression algorithm and you will lose quality.
Which Canopus programme have you used? Edius?
What were your output settings?
What are your MF project settings?
Make sure you are using the same settings in MF as you output in Canopus.
I can't think of a reason why just the slow motion should become jerky.
If you play the canopus made mpeg2 in your dvd playing software, is it jerky in the same place?
If yes, you have a problem in canopus, if no, then it is most likely the MF settings.
classicwest
Hi Graham. I use Let's Edit 2, a great easy program by Canopus.
I save my footage to MPEG 2, program stream at approx 70,0000 Picture 30 iBBP ticked and save it
If I use this programs own rendering there is no jerking. If I use MF 3.5 there is also no jerking.
When I use MFP7 and don't render it again, there is jerking throughout the movie, but only where there is slow mo, it is like a freeze frame every few seconds, but as I said, only whilst there is slow mo.
If I render in MFP7 as well as in Let's Edit there is no jerking, but of course the movie is slightly lower in quality in playback. I have had this same problem since I first bought MFP7. I do a fair bit of slow mo work in a movie.
Thanks Allan
Thanks Allan
skier-hughes
- Microsoft MVP
- ram: 4GB
classicwest
Render
Hi Graham
Edit program settings are:
Stream : MPEG2 Program Stream
[Video Settings]
Bit rate : CBR, 7700000 bps
GOP Settings : IBBP, Picture = 30
Profile && Level : MP@ML, Size : FULL ( 720 x 576 )
ticked is. Encoding Mode : Quality the Most
Sequence Header : Place all GOP's
MFP7 settings: 16:9 lower fields first DV
That's all the settings. I can't see anything wrong with these settings.
Thanks Allan
[Video Settings]
Thanks Allan
- ram: 2 GB
- sound_card: Intel GMA 950
In addition to the problems of loss of quality when you save an MPEG and then Save that MPEG and then Save that MPEG etc. You have introduced a further factor into the equation.classicwest wrote:Hi Graham. I use Let's Edit 2, a great easy program by Canopus.
Thanks Allan
Your "lets Edit by Canopus" program appears to use a different IBP structure to MovieFactory 7"
classicwest
- ram: 2 GB
Point 1. Stick to one editing program - they behave differently as you can see just by looking at the GOP structure - and that is on top of the deterioration caused by re-saving a MPEG2 file which is a lossy format.classicwest wrote:What can I do? As I have written MF3.5 is compatable, but it is old technology and not good enough in other areas?
Is there a solution? Is it possible to make the movie render it to AVI then render to MPG2 in MFP7, I have tried it but does not seem to work?
Point 2. There is no point in rendering from MPEG2 to AVI then back again.
Firstly you cannot put back what has already been taken out. whilst there is no loss going from MPEG2 to AVI. there will be loss when you later convert the AVI back to MPEG2.
Whilst the following was written for VideoStudio - the principles apply just as equally to MovieFactory.
Suggested work flow by SJJ1805 for Video Creation
classicwest
That's OK, but I still haven't solved the problem.
I am sticking to the same editing program and that works well.
MFP7 is causing the footage in slow mo to jerk. This is the issue I need to work out. On how to stop MFP7 doing this without me having to render it again in MFP7 because I don't want to render it twice.
Is there a solution that you know of.
skier-hughes
- Microsoft MVP
- ram: 4GB
classicwest
render
It is set to Lower fields. What should it be set to?
No Fields
Lower fields first DV
Upper fields first
Which one.?
No Fields
Upper fields first
Which one.?
skier-hughes
- Microsoft MVP
- ram: 4GB
