Splashed out and bought the boxed version of VS12 Ultimate (very hard to purchase an upgrade boxed version in Australia the advertised outlets for the product do not carry upgrades and Corel who have an office in Sydney looks like closing it down as nobody there returns calls and the 1800 number now disconnected and with the fiasco last time with direct on line purchase through Corel website boxed is the only way that will buy their software) and the install went all ok until Stienberg wave lab LE V6.0.
Running the VS installer the last part of the process you get the OSD message of installing wavelab please wait and does not enter the install phase the HDD Led just goes idle. So know sometimes takes quite awhile to install some programs so gave it 50 minutes then had to power reset as could not even get the task manager up to close the installer.
Next rebooted and navigated to the autostart exe program inside the wavelab folder in utilities folder on the disc running normal or administrator does not start the process (system does not latch this way just does nothing).
Next tried running the setup exe will start install process comes up with where the program will install etc etc progressing to the MS warning about not having been passed by MS click continue anyway then my system just latches and have to do power reset as again can not even launch task manager.
Having the task manger running whilst trying to install can not see what process launched causing the problem and sys error log showed 3 red Service Control Manger error ID7022 this may have been when rebooted the first time of the lock up and quite a number of info entries of errors ID7035 after the 3 red ID7022 errors do not know if even is part of the problem.
Tried running as administrator also has same problem. Tried disabling all security except firewall (FW setup if any SW trying to access the net my FW software would seek permission first).
Running XP Pro Sp3 fully updated
T7200 core2 2.0 Gig
4 gig RAM (yes I know 32 bit system can only yarda yarda it was cheaper to by matched Kingston 4 Gig packs then).
Any help or suggestions would be helpful.
After 3 fruitless hours of gave up for today
Or just keep using the other usefull Audio editors that have like Audacity or the one from AVS it has some cool filters and stuff to clean and fix.
But would be nice to get the Steinberg going never had a Stienberg before
