Please help with VS8!
Jamie
Post by Jamie »
Trying to transfer project onto DVD. DVD should hold 2 hours, project is only 1 hour 11 minutes but won't fit. Is there a setting I should change to make it fit.
Post by BrianCee »
After you have clicked on "Share >> Create Disc" in the bottom left corner of the "Create Disc" window you will see two icons - click on the left one (square with little lines on) - from the pop-up choose "Disk Template Manager" - - choose "Fair quality" from the list - click "Close" - burn your disc.
DVDDoug
Moderator
Post by DVDDoug »
Use a lower bitrate (lower quality).
Sorry, I don't have VS on this machine so I can't tell you exactly what to click.
I'll bet yuu're using LPCM audio. Two hours of LPCM are going to eat-up over 1GB. AC3 or MPEG audio should take-up about one-third as much space.
[EDIT] - Brian beat me to it... do what he said! :lol:
LPCM is standard on all players. all PAL player must also play MPEG audio (AC3 is optional). All NTSC players (i.e. USA) must play AC3 (MPEG audio is optional).
Jamie
Post by Jamie »
Thanks! Saved me a LOT of time and trouble!
alanball
motherboard: Gigabyte Technology B450M H
processor: AMD Ryzen 5 3600 6-Core
ram: 16 GB
Video Card: NVIDIA GeForce GTX 1660 SUPER
Hard_Drive_Capacity: 2TB+480SSD
Monitor/Display Make & Model: ASUS VN247
Corel programs: VS10, VS2018 Ultimate, VS2021 Ultimate
Post by alanball »
Hi Guy's,
I'm just getting into Video editing with V8 and read this post with interest. I looked up LPMC on the internet to find out what it stood for (now I know), but could you please tell me if I copy a part of a CD sound track into VS8 what format does VS8 save the sound track in when I'm working with an AVI file?
Alan
Alan Ball
THoff
Post by THoff »
An audio file ripped from a CD is normally also in LPCM audio format, but using a different bitrate than the one used by DVDs.
However, that's not a problem. UVS will convert the source material into a DVD-compliant format.
alanball
ram: 16 GB
Post by alanball »
Thanks THoff.
Alan Ball
