Transition artefacts
erdna
- motherboard: Gigsbyte H81M
- processor: I7 4770
- ram: 16GB DDR3
- Video Card: Intel HD4600
- sound_card: Intel display audio
- Hard_Drive_Capacity: 1TB 7200rp
- Monitor/Display Make & Model: Panasonic TX32cx600e
I needed a crossfade between two clips containing quite a lot of motion. Knowing the blips problem I did put the clips on my timeline without crossfade and created an AVCHD file. Then I used the unified clip, searched the exact end of the first clip and made a cut (scissors) where I then inserted my crossfade. I don't know if it is just by luck, but no blips anymore!j
erdna -- if all you are after is a cross fade, and you have X2, then simply drag the beginning of the second clip over the end of the first clip and you will have a cross fade... I confess I don't know what might happen re the blips with AVCHD, but it certainly gives you a cross fade. But since no transition effect is actually inserted, perhaps it will get around the blip problem...
erdna
- ram: 16GB DDR3
