LAWRENCE
No audio!!!
No audio!!!
I have Video Studio Pro X2 and everything is O.K. apart from I have no sound when I've captured a video from a newly purchased bullet cam
. There's sound on the cameras recording device and on the media player when reviewing on the PC. Initially there was a horrible, metallic noise, so I downloaded the latest patch, now there's no audio whatsoever. Any ideas please? Thanks.
LAWRENCE
LAWRENCE
skier-hughes
- Microsoft MVP
- motherboard: gigabyte
- ram: 4GB
- sound_card: onboard
Bit confused as you say there is no sound when capturing, but you can review the file in a media player and the sound is fine.
Is there no sound during capture? If so, it could be a compatibility problem, that you can live with as you have sound in the captured file.
Is there no sound when importing the captured file into VS? If so, again compatibility would be my guess with the audio file type.
Is there sound when you listen to the bullet cam live, but VS doesn't record it?
Use something like avicodec or GSpot to identify the audio file type in use if your manual doesn't tell you.
- ram: 2 GB
- sound_card: Intel GMA 950
Please view the following links:
Please read this before posting
Please click here -->
so that we can then view your system specifications.
Hi'ya Graham,skier-hughes wrote:Bit confused as you say there is no sound when capturing, but you can review the file in a media player and the sound is fine.
Thanks for the reply. I've now got the results:-
codec=mp4v
name=MPEG-4Video
status=Codec Status Undetermined
So what does this all mean then? Should VS be able to play this audio or do I have to download something? Thanks once again.
LAWRENCE
Apologies, I'm new here. I called Corel and they mentioned this forum. I figured it'd probably be quicker to ask the question rather than trying to find it in the FAQ's.sjj1805 wrote:Please view the following links:
Please click here -->so that we can then view your system specifications.
LAWRENCE
skier-hughes
- Microsoft MVP
- ram: 4GB
O.K., I have updated my profile.
Graham, to answer your questions:-
"you say there is no sound when capturing, but you can review the file in a media player and the sound is fine."
DEPENDING ON WHICH MEDIA PLAYER, YES I CAN HEAR THE SOUND (QUICK TIME & WIN MEDIA PLAYER DON'T PLAY THE SOUND.
"Is there no sound during capture? If so, it could be a compatibility problem, that you can live with as you have sound in the captured file."
WHEN I SAID CAPTURE, I MEANT WHEN I CAPTURE & IMPORT INTO VS. THERE IS SOUND WHEN I MAKE THE INITIAL RECORDING.
"Is there sound when you listen to the bullet cam live, but VS doesn't record it?"
YES, THAT's CORRECT.
I'm sorry, but I'm not technically minded when approaching PC's, I'm at my happiest when I turn it on and run the programmes, please bear with me.
LAWRENCE
LAWRENCE
I'm recording straight onto an SD card then via the card reader (USB) to the PC. It's a puzzling onesjj1805 wrote:How are you connecting the bullet cam to the computer?
Are you using the AV out or are you attempting to use USB.
Thank you for completing your system specifications - at least we can rule out Vista / windows 7 related issues.
- ram: 2 GB
Ah now I follow.... a SD card.
One of my sons had a HD Camcorder that records in MPG4 directly to an SD card and the only way we were able to do anything with his videos was to convert them first using Super (Free software). We would convert them to MPEG2 because this was our intended final format so that we could create a Video DVD.
I would give that a shot.
skier-hughes
- Microsoft MVP
- ram: 4GB
Thanks Graham & Steve, I now have sound
. But..............I converted the file to MPEG2 but can't open it (or any other videos that are on the HD) via VS. So I burned it onto a disc and used the "open with" facility. A VERY long winded way to do things, but for now will be O.K.
MANY thanks for your replies and patience.
LAWRENCE
LAWRENCE
skier-hughes
- Microsoft MVP
- ram: 4GB
