WMV. and audio sync issue
Mad_Lenny
Post by Mad_Lenny »
Hi Guys
I'm having a bit of an issue where I've edited some footage into clips WMV zune (640x480) 30 fps, no problem, however when I add two of this clips together along with 3 jpeg images and 3 turn page effects and render again in the same format the audio isn't synced properly. It works fine if I render as .mpeg but unfortuately I need them as .wmv
Any ideas would be greatly appreciated
Mad_Lenny :?:
Post by Black Lab »
Why are you first rendering the clips to WMV, then adding them to another project and editing them again to WMV? Can't you take the original clips and do all your editing and rendering just once?
Mad_Lenny
Post by Mad_Lenny »
Ah, the clips also need to be distributed seperately...but your suggestion might well work round this problem, I'll give it a go now!
I guess the reason we're a bit stumped is because my colleagues' machine is going through the exact same process but not having this problem. The machines have identical hardward but mine is running Windows 7 (x64) to his Vista (x64) hope it doesnt mean a rebuild - am quite liking Win7 :)
Mad_Lenny
Post by Mad_Lenny »
Many thanks Black Lab, its working fine now we're rendering straight from the raw footage...(quicker doing it just the once as well!!!! :oops: )
Post by Black Lab »
8)
