Multicamera work
Doug2006
- motherboard: Asus M4A89GTD pro usb3
- processor: AMD Phenom II X6 1055T
- ram: 8 gigs
- Video Card: Integrated Radeon HD 4290
- sound_card: ACL 892 8 channel
- Hard_Drive_Capacity: 90ssd +
- Monitor/Display Make & Model: Asus VH238H lcd
Multicamera work
I have two clips of the same thing from two different cameras. I put one clip in the main track and one in the overlay track. I can cut out portions of the overlay track and then play the project and it is good in that I switch back and forth between cameras but there is no transitions. No fade from one to another. Can this be done and do I have to do a lot of manually tweaking for each one or is there a default that goes in every time I make a cut? Doug
- ram: 2 GB
- sound_card: Intel GMA 950
You could do it the old way - before we had multiple overlay tracks.
Please see Multi Camera Editing
No, you cannot transition between tracks (
). The workaround is to put all your clips in the overlay tracks, overlapping them slightly, and using the Fade In/Fade Out buttons to simulate a crossfade transition. The main video track does not allow for the Fade In/Out, that is why you must use the overlay tracks.
Jeff
Dentler's Dog Training, LLC
