Softening the edges of a photo
Sherry92
System_Drive: E
motherboard: Toshiba
processor: AMD Athlon II Dual Core M300 2.0GHz
ram: 3GB
Video Card: 12345
sound_card: 12345
Hard_Drive_Capacity: 309.99 GB
Post by Sherry92 »
I am using the Paintshop Pro to touch up my photos. Is there a way that I can soften the edges of my photo and not the whole picture? I am still learning this stuff. Alot to learn.
Tim Morrison
Moderator
motherboard: Asus P4533
processor: 3.16 GHz
ram: 2GB
Video Card: Radeon HD4650
Hard_Drive_Capacity: 2.6 TB
Monitor/Display Make & Model: HP LP2275W
Post by Tim Morrison »
Try Adjust > Depth of Field.
Tim Morrison
C-Tech Volunteer
JimL
Post by JimL »
Duplicate your layer.
Make a new mask layer (hide all)
Select all
Selection>Modify>Select your selection border >inside (amount you want to blur from outside edges)
Feather to get gradual fade to sharp picture (start with 8 or 10)
Fill selection with white.
Make duplicate layer active and apply blur (You can play with the blur settings but I find it easier to use a strong blur then adjust the layer opacity to get the effect I want.)
Merge layers when you are satisfied.
STRONGLY advise not working on the original file so you can go back to the original later for adjustments or different effects.
JimL
Put down the GPS and look out the window
