I am looking for some help on syncing music to video. I am doing different sports clips and would like to give this a shot.
Any suggestions on how to do this would be greatly appreciated. Additionally if there is any software that may assist in this process, please let me know.
Sync Video to Music
fngman
- motherboard: Gateway WG43M
- processor: 2.33 gigahertz Intel Core2 Quad Q8200
- ram: 4 GB DDR3
- Video Card: ATI Radeon HD 4600 Series
- Hard_Drive_Capacity: 640 GB
Clevo
- motherboard: Asus PK5
- processor: Intel Quad CPU Q6600 2.40GHz
- ram: 4GB
- Video Card: NVIDIA GeForce 8600 GTS
- sound_card: Auzentech X-Fi Forte
- Hard_Drive_Capacity: 850GB
There is probably an easier way to do it but I like to do it manually....
I do it by adding cue points.
Place the audio on the track...set the markers to "cue point" rather than "chapter point".
Press play and click on the mouse with the beat.
This will leave a cue point at each beat and then add the segments of video and it will snap to the cue point marker.
It helps if you listen to the song a few times in case there is a middle 8 you want to skip or the song has different tempo's in sections.
I find this imperfect but I like the organic feel of it.
I also like to experiment and work on the off-beat...or cue in guitar riffs/ drum breaks
If you look in the Tutorials section you will find some answers.
Also, you would be surprised how many times the mind perceives that video is actually synced to audio. The phenomena is called Apophenia.
Apophenia is the experience of seeing patterns or connections in random or meaningless data. The term was coined in 1958 by Klaus Conrad, who defined it as the "unmotivated seeing of connections" accompanied by a "specific experience of an abnormal meaningfulness"
Jeff
Dentler's Dog Training, LLC
- ram: 2 GB
- sound_card: Intel GMA 950
Read this
Aoccdrnig to a rscheearch at Cmabrigde Uinervtisy, it deosn't mttaer in waht oredr the ltteers in a wrod are, the olny iprmoetnt tihng is taht the frist and lsat ltteer be at the rghit pclae.
The rset can be a total mses and you can sitll raed it wouthit porbelm.
Tihs is bcuseae the huamn mnid deos not raed ervey lteter by istlef, but the wrod as a wlohe.
Taht is azimang.
It's actually harder to write it than read it!
Jeff
LGO
- motherboard: Intel Corporation D915PBL AAC67720-301
- processor: 3.20 gigahertz Intel Pentium 4
- ram: 3 gb
- Video Card: ATI Radeon X300-X550-X1050 Series
- Hard_Drive_Capacity: 200-750gb
allsha ewa iscussda istha inha igpa atinla?
(Sorry, couldn't resist
I manually do the synching like Clevo, but I'm incredibly anal about it. I put the music in an audio editing software and look at a graph of the music piece. Real easy to spot beats, high points, etc. I write down the time points of the beats in the music.
Obviously, I then load the music clip into VS and start my inserting of clips, stills and begin editing according to the time points I wrote down. Then, I render and view it noting which images or clips are a little off. You never get it right the first time! Finally, I adjust the durations of the images and clips that are off beat. Believe me, the final adjusts go really fast because you've put the effort into the front end of the process.
I've looked at and tried different pieces of software that claim to do this but the result was so far below what I can do that I don't use them.
Doing it manually (synching to music) is probably the most tedious thing I've ever done in VS, but I began doing it with Version 3 in 2000 and have made 6 different videos like this since then. They're as close to "perfect" as I think is possible. (Sorry, don't mean to sound conceited!)
Doing it manually all depends upon the music clip, having enough subject material, available time, and the patience and desire to get it precise. If you don't need or want it precise, forget what I wrote, above!
oodga uckla!
oodga uckla!
Proud VS user ver. 3, 4, 5, 7, 8, 10+, ProX2, and ProX4
Currently - VS ProX4 14.2.0.23
C3DPS ver 1.0.1
GIF Animator
C3DPS ver 1.0.1
GIF Animator
- ram: 2 GB
Click here to see how I do it.
