Capture frame as an image
erdna
motherboard: Gigsbyte H81M
processor: I7 4770
ram: 16GB DDR3
Video Card: Intel HD4600
sound_card: Intel display audio
Hard_Drive_Capacity: 1TB 7200rp
Monitor/Display Make & Model: Panasonic TX32cx600e
Post by erdna »
I have a 1920x1080 clip(AVCHD) on my timeline, and want to save a particlar frame in it as an image It shows as a 1024x576 .JPG. Where is my 1920x1024 format gone?
Post by Trevor Andrew »
In clip mode you should be saving the same as the original video size (clip--save as still image....)
OR
Set the project properties to match your video file size 1920x1024. (You will have to use Mpeg2 compression)
Then use Tools-Save current frame as image, must be in ¡¥project playback ¡¥ mode. (will save as you see it on screen)
erdna
processor: I7 4770
ram: 16GB DDR3
Post by erdna »
Thanks for your quick and complete reply. Do you happen to know if the resulting imagea are de-interlaced frames or line doubled fields? Is there any setting to change this?
File-Preferences-Capture Tab shows the Image Capture as De-interlaced. (By Default)
I have always kept this option.
