Data Buffer Under run
dasdazu
Post by dasdazu »
I have struck a new problem (for me) with MF 3.0. Near the end of burning a disk I get an error message saying there has been a Data Buffer Underrun' - or something similar. The tick box under the Options menu for turning on 'Buffer Under run' protection is shaded out. I haven't had this problem before. Has anyone else experienced it? Any reason why? The day before I did exactly the same thing with another disk (both DVD+RW) and it worked perfectly.
ipeppes
Re: Data Buffer Under run
Post by ipeppes »
Did you get an answer ?
I just bought DVD MovieFactory 3 / Applied the patch / and do not have the 'buffer underrun protection' option appearing when using the 'Direct to DIsc' option
Ioanis
dasdazu
Post by dasdazu »
I do not remember getting an answer but I figured that I was trying to fit too much on the DVD as on the video settings I had selected 'Best' or the equivalent of the top rate of compression - i.e. minimum or no compression and that took the files over size. Once I reduced that to standard or the next above then everything fitted.
I hope that helps.
