I have hit a slight problem.
When using multiple screens how do I move the editor to the other scren?
Using the editor on multiple screens
MIKEL
- motherboard: ASUS P6X5bl Premium
- processor: Intel i7 930
- ram: 24GB
- Video Card: NVIDIA GEForce 8500
- sound_card: Built in 5.1 surround
Many thanks
Mike
Mike
Clevo
- motherboard: Asus PK5
- processor: Intel Quad CPU Q6600 2.40GHz
- ram: 4GB
- Video Card: NVIDIA GeForce 8600 GTS
- sound_card: Auzentech X-Fi Forte
- Hard_Drive_Capacity: 850GB
Having only recently started using two monitors at work it seems the only way to drag the software GUI acros to the other screen it to reduce what you want to move across into a windowed frame (which VS doesn't allow you to do) you can then click and drag the GUI across to the screen you want.
If you have two monitors connected to the same graphics card then digitally you will be seeing exactly the same image...except of course that monitors will interpret those colours differently.... I usually find TV Plasma screens the most troublesome as most people seem to set them up with higher colour hue levels.
Professionals use a colour spectrum graph and adjust the screen while displaying the colour bars so that all screens interpret the colours in the same way. We don;t have that luxury.
To solve your problem though what you will have to do is swap your connectors so that when using VS you can display it on the monitor you want. I wouldn't be messing around with colour levels too much...VS by default does a good job with the default colour levels if and only if..the source material was shot reasonably properly with good white balance levels.
