After performing some disk clean-up with System Mechanic 5 and archiving over 400 junk files I now get an application error
When closing the Create Video Disk session I get the DVDMF.EXE application error prior to returning to the Launch menu
The error message is as follows
The instruction at "0x76bf1913" referenced memory at "0x76bf1913". The memory could not be "read"
The registry was not modified, since I was only performing a disk clean-up - I did restore some of the files in my document settings...temp directories without any success
I also performed a clean uninstall and install using steps described in a previous post and I am still getting the same message
I will try and restore all of the archived files and see if this error message will no longer display - but I would like to avoid this since my objective was to clean some junks from my system
Any suggestions
Thank you all
