Capturing original file names
Posted: Thu Aug 27, 2009 4:55 pm
by david_lexicon
I have captured 5 dv tapes to my PC. I have produced about 6 files in .vsp taking scenes from the 5 dv tapes. Unfortunately I erased the original captured files. Now I have a relink problem as I have captured again the 5 dv tapes and the new filenames are now different from the original captured files.
How can I capture again the original files with the original filenames?
Posted: Thu Aug 27, 2009 5:41 pm
by DVDDoug
I don't think you can do that (I think the name is derived from the date & time), but you can rename the files back to the old names. (Open the folder in Windows Explorer. Right Click. Select Rename. Or, or click twice with a pause so you don't "double click" and directly edit the name.
Posted: Thu Aug 27, 2009 5:59 pm
by david_lexicon
DVDDoug wrote:I don't think you can do that (I think the name is derived from the date & time), but you can rename the files back to the old names. (Open the folder in Windows Explorer. Right Click. Select Rename. Or, or click twice with a pause so you don't "double click" and directly edit the name.
How do I know what was the the name of the original file?
Thanks.
Posted: Thu Aug 27, 2009 6:38 pm
by mitchell65
If your new files are all in the same folder can you not just re-link one of them and then the others will automatically re-link. Or have I not understood the problem?
Posted: Thu Aug 27, 2009 7:47 pm
by david_lexicon
VS will not recognize the other new filenames because have been re-captured.
I think this cannot be done. Maybe I can change the PC's clock for the day I captured them. What do you think?
Thanks.
Posted: Fri Aug 28, 2009 12:37 am
There is a little more to it than just re linking.
You can only re link to a video that is as long as or longer than the original.
If you recapture the video and it is smaller - even by only a frame then you will not be able to re link to it.
Posted: Fri Aug 28, 2009 8:07 am
by david_lexicon
Yes.....you are right.
Thanks.
