Crashing as a user
selhurst
Crashing as a user
Post by selhurst »
As a newbie to forums I may be repeating something that has already been addressed and I just haven't found it. However here goes
When I use Video studio 12 as a user it frequently crashes, particularly when I play a video clip from the library direct. However it works OK when I play it as adminstrator. As I don't like working as adminstrator I would like to correct the problem. Does this mean a reinstall and if so will I keep all the work I have done to date (except for any settings I guess)?
Selhurst
Clevo
motherboard: Asus PK5
ram: 4GB
Hard_Drive_Capacity: 850GB
Post by Clevo »
on what operating system? Vista (32 or 64 bit) or XP?
What are your system specs?
DVDDoug
Moderator
Post by DVDDoug »
I don't know why administrator has any effect, except maybe that as a regular user you may have some conflicting program running in the background.
I doubt that uninstalling & re-installing will help, but sometimes it's worth a try when you've run out of ideas... You won't loose any saved video files, and I don't think you'll loose any saved projects.
Most crashes have something to do with the your particular file or file format. The more-compressed formats tend to cause the most trouble. If you're working with DV/AVI files directly from a MiniDV camera (13GB per hour), you shouldn't have any problems. If you have a camera that makes MOV or MPEG-4 files, you might have trouble. If you download files from the Internet, you will run-across some files that cause trouble!
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
mitchell65
motherboard: Dell Inc. 04GJJT A00
processor: 2.80 gigahertz AMD Athlon II X4 630 Quad Core
ram: 4Gb
Video Card: ATI Radeon HD 4200
Hard_Drive_Capacity: 560Gb Sata
Post by mitchell65 »
If you save your projects in a folder outside the Corel folder they will be safe. But to be even safer why not back them up to a disc. The VSP files are not very big anyway. You might start backing up all your video related files on a regular basis. Always a good policy and storage media is relatively cheap nowadays.
John Mitchell
selhurst
Crashing
Post by selhurst »
Operating system - XP
Computer - Intel(R) Core(TM) Quad CPU
Q6600 @ 2.40GHz
2.40 GHz GB of RAM
I save all my files to an external hard drive but do all my temp work on the C drive
selhurst
Post by selhurst »
In addition all the files are *.m2t files downloaded from a disc recorded on a Panasonic HDC-DX1 video camera
Post by Trevor Andrew »
Have you updated X2 with :- X2 Patch
Also have you manually installed Direct X, see announcement at top of this forum.
