[Request] High Res Brushes!!
SnedekerDesignz
- motherboard: Nvidia Geforce 8200
- processor: AMD Quad Core 9850
- ram: 4GB
- Video Card: Nvidia Geforce 8400
- sound_card: Stock
- Hard_Drive_Capacity: 400GB
Can't many many Tshirts with no high-res brushes. Is this a feature in PSP12?
Visit my blog at craigps.co.nr
Tim Morrison
- Moderator
- motherboard: Asus P4533
- processor: 3.16 GHz
- ram: 2GB
- Video Card: Radeon HD4650
- Hard_Drive_Capacity: 2.6 TB
- Monitor/Display Make & Model: HP LP2275W
SnedekerDesignz
- ram: 4GB
- sound_card: Stock
I'm not sure how you intend to use larger "brushes" but you might try using the available brushes to make a square pattern and or texture and saving them to the proper folder. You can then outline your intended graphic with the selection tool using an inside feather of 30 or so and fill with your new pattern/texture. Remove the selection (save if you might wish to draw a similar graphic another time) and then use the normal brush to "paint" the feathered edge giving a look which is close to the hand drawn effect achieved by drawing the whole graphic. By using the + and - selection tools you can apply other patterns or cut outs inside your primary graphic. This should work well on the type of T-Shirt Graphics. If your graphic includes text this same procedure will work on selected text for a hand drawn look.
JimL
JimL
Put down the GPS and look out the window
