Mark-in/out resetting - cursor stay put
lazael
Post by lazael »
What trick does one use to get the jog slider to remain at the current timeline position when resetting the mark-in/out settings?
Ken Veal
motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
processor: 360 gigahertz Intel Core i9 900K
ram: 32 GB
Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
Hard_Drive_Capacity: 1250GB SSD
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Mark in/out
Post by Ken Veal »
Are you using the triangle below the preview window to move to the mark in/out position or the one above the timeline, because the cursor stays put
in the timeline................................Ken
lazael
Post by lazael »
With my workflow approach :shock:, I delete the selected range (mark-in/out area) after working on a clip. The only way I can do this, is to switch the project and then hit the home and end tabs repeatedly. This results in the whole timeline being playable. Unfortunately my cursor scrollbar is now either at the beginning or the end of the project.
My trick is to remember the timecode value and re-enter it. Hitting enter puts my job bar where I was last working, and I can then continue with my further editing. I just wondered if anyone had a quicker method :?: .
Ken, I already tried your method thanks - no luck.
Ken Veal
ram: 32 GB
Cursor management
Post by Ken Veal »
Select clip
move cursor to mark in point in Project mode
Click 0n [
Repeat for mark out ]
Cursor stays there in time line
Remove red line (Preview Range) by dragging left black triangle all the way to the left (below preview screen)
drag right black triangle all the way to the right
