Problems with AVCHD transitions
vancellfoto
Post by vancellfoto »
Hi - I'm still a newbie on videography so please bear with me :)
I have a Pansonic AG-HMC71E solid state video camera.
My computer specs are:
Laptop - Intel Pentium Dual Core
Memory - 2.5GB
System: Vista
External Drive: Maxtor 1TB
Internal Drive: 150GB
Recently I started to have problems with transitions between clips. This is shown only on TV when I convert the project to MPEG2 and
burn to DVD. On the MPEG2 file when I view it on the computer, everything is fine.
BTW I use Ulead's DVD Moviefactory to burn to DVD because it has some fantastic menus.
This is the way I work. I load all the video clips on the Library, then I convert all to smart proxy so that I can view realtime on the timeline. Then I edit were necessary the clips with the multi trim. Then after I'm satisfied I insert a transition between the clips.
After the whole project is done, I go to share video and choose the DVD pal feature and convert the whole project to mpeg.
Is there another way which I can solve this problem?
Welcome to the forums! :lol:
Now you tell us you have a problem with the transitions, but you don't say exactly what the problem is!!! :roll: However, I guess it is much the same as just about all other users of the AVCHD format have been having for simply ages, I am afraid. Please see this enormously long thread, and you will realise that (sadly) you are not alone: http://forum.corel.com/EN/viewtopic.php?p=170419#170419
Corel have been well aware of this bug for more than a year but have not produced any fix. I am not holding my breath... :cry: :cry: :evil:
vancellfoto
Hi Ken, thank you for welcoming me to this forum!
Oh yes I have been reading that tread any trying to understand the nature of the problem. I have found out that normally the users are referring to HDV or AVCHD discs.
My projects all finally end up in standard DVD discs.
Well the problem is this after a transition the clip jumps/jerks a little. Now this problem has occured very recently as I have been using this VS for quite a while.
What I used to do before is that I converted all the clips into MPEG2 with the software HDwriter provided by Panasonic and everything was fine.
Now I am working on a project and found out that after very long clips (of 2 and 3 minutes) the transitions work fine but after very short clips the trouble starts.
Is there a way around this?
I am afraid that the long thread is not about HDV or AVCHD discs. It is a general problem with editing AVCHD and adding transitions, and then producing a new file. Nothing more, nothing less. And no way around... Moreover, it is not really a problem with HDV (I edit HDV all the time), only with AVCHD...
vancellfoto
So there's no solution?
In the meantime I am going to split the project in 2 mpeg clip and rejoin them in Ulead's Movie factory. If this does not work I will retrace back and convert the AVCHD in mpeg2 clips.
Hopefully I solve this problem
Post by Black Lab »
Please let us know if you do. Many will be interested.
vancellfoto
Hi There!
Finally I found out why Panasonic bundled their HDWriter software with the camera.
After a painstaking job of converting all clips into MPEG2, because the software does not allow you to convert a scene into single clips but one whole clip, I had to resort to selecting scene by scene and converting each.
After this process I relinked all the clips on VS and made sure that the project had the same properties as the clips ( another painstaking job as VS does not allow batch relinking ).
After that I rendered the video by selecting same as project settings.
The rendering now was very fast for in 1/2hr the project was ready and when I played back on Windows Movie Player there were no jumps after any transition used.
As I said before my projects all end up as standard DVD or DVD DL (PAL).
I hope that this helps anyone that uses Panasonic AVCHD.
Clevo
motherboard: Asus PK5
ram: 4GB
Hard_Drive_Capacity: 850GB
Post by Clevo »
Kif inti Vance? :D
are you happy with the results with regards to quality?
