dvdws2 menu animations not moving/animating
moonwalker
Post by moonwalker »
i been using dvdws2 for a long time without any problems, exept now for some reason when i import an animation gif file eg: text ,and place it in to the menu screen it appears as a still image after i press play to preview it , and it also has a black colour around it where it should be clear ,
it all works good when i burn it to dvd , it just not displaying correctly while working on it .
before i used to import a gif animtion weather it was text or an image that was moving i could preview it and it would animate as it should . but not now , any help please on what could be causing this .
thanks
Coral
motherboard: Asus P8P67 Pro Rev. 3
processor: Intel Core i5 2400 Quad Core 3.1GHz Socket 1155
ram: 8 GB
Video Card: Gainward GT 520 1024 MB RAM
sound_card: On Board
Hard_Drive_Capacity: 500 GB X2
Monitor/Display Make & Model: AOC 19 inch CRT tube
Post by Coral »
Have you updated the application ?
Have a look here:
http://forum.corel.com/EN/viewtopic.php?t=35780
moonwalker
Coral wrote:Have you updated the application ?
Have a look here:
i have 2.232 . it has no other update yes ?
that link u gave me isnt the problem i am having , its actual gif animations i import that dont work .where before they did , and the animations that come with the app also dont move when they are in the menu window .
Coral
ram: 8 GB
Post by Coral »
Have a look here:
My problem started when I updated from v2 to any other update patch.
Whenever I use animated backgrounds in chapter menu backgrounds the animation will not work.
When I went back to V2 all returned to normal. But lost the option to choose Auto Add Chapters > By fixed intervals. The only solution for me has been to update to V2.232 and load the motion backgrounds manually.
Tru updating your Direct X
Please click here --> Image so that we can then view your system specifications.
Coral
ram: 8 GB
Post by Coral »
I already have the Direct X (March 2009) installed.
moonwalker
i updated my profile info , hope that helps u help me . i also have latest directX .
Windows XP PRO SP3
Intel Core2 e6700
2.67ghz
Ga-965p-dq6 motherboard
2gb ddr2 memory
Geforce 7950 gx2 1gb
Seagate sata2 250gb 16m cache
250gig Hard drive
Pioneer dvr-111dbk dvd writer
LG HL-DT-ST_DVDRAM_GSA-H62N
LG HL-DT-STDVDRAM GSA-4120BA115
500 w power supply
The only thing that concerns me is XP Service Pack 3, I had a few quirks after that
( see Anyone got a problem with XP SP3 and MSP8 ? )
At this time I can only suggest the text book answer and try a re-install of DVDWS 2
Coral
ram: 8 GB
Post by Coral »
If you do a reinstall of DVD Workshop 2, try it first without the update patches.
moonwalker
sjj1805 wrote:The only thing that concerns me is XP Service Pack 3, I had a few quirks after that
ok thanks .
it worked fine with sp3 b4 , its just something thats happened for no doing of myself .
is it anything to do with overlay settings in Nvidia controll pnl ?
I will do a reinstall if it persists after i try a few over things .
moonwalker wrote:..........
ok thanks .
When a program that was previously working fine suddenly begins to misbehave then you have to investigate what has changed.
Think carefully about what has happed to your computer since the last time it worked OK.
Have you had a sudden loss of electricity causing an abnormal shutdown of the computer.
Have you installed any new software
Have you removed any.
have you installed any new hardware.
have you had any of those automated Windows Updates.
Please view the troubleshooting guide here
moonwalker
ok thanks .
no none of the above .
i have my pc working in tiptop condition . and havent changed or unistalled or installed anything new or done any changes in any way .
i think to reinstall it may be the best thing to do .
