Unable to preview in X2 pro video studio
raejohn
- motherboard: Dell Inc.0JC474 800 megahertz
- processor: 2.80 gigahertz Intel Pentium 4
- ram: 2040mb
- Video Card: Inter 82915G GV 910GL Express chipset family
- sound_card: device Instand ld Root Media MS_MMACM
- Hard_Drive_Capacity: 80gb
- Monitor/Display Make & Model: 17" LCD (analog only)
Hi I have recently purchased X2 Pro have added the patch and a Microsoft DivX suggested by Corel. I have made a movie which I can burn to DVD but in the process am unable to Preview either at the template/intro page or at the Remote Preview. I am mainly using JPEG photos in my composition and am only a novice so if replied could be straight forward and not technical this would be appreciated. Any ideas???
javascript:emoticon(':?:') Yes I did mean Direct X Sorry
Please try updating your DirectX, as that cures many preview problems.
DirectX Update
DirectX Update
Jeff
Dentler's Dog Training, LLC
raejohn
- ram: 2040mb
Yes it was sorry.New at this
Ken Berry wrote:I rather suspect this was a mistype for DirectX...... a Microsoft DivX suggested by Corel
Did you try a re-install after updating your DirectX? Worked for me after a similar problem.
Jeff
raejohn
- ram: 2040mb
Thanks for that suggestion. I will uninstal and reinstal and see if the Direct X addition has helped.
Hello everyone..Black Lab wrote:Did you try a re-install after updating your DirectX? Worked for me after a similar problem.
Thanks for the valuable info..
I have just bought and installed VS-X2 and had the same problem with preview during Share to DVD etc..
Updating DirectX cured the problem but during the download/installation, I noticed a silly situation, waiting to catch us all out.
Microsoft's instructions for this download are;-
In the File Download dialog box, do one of the following:
To start the installation immediately, click Open or Run this program from its current location.
To copy the download to your computer for installation at a later time, click Save or Save this program to disk
Whether you run the downloaded file from the download, or by double clicking directx_mar2009_redist.exe, this only extracts the files to the designated folder.
It Does NOT install the directX update.
You then need to open the folder that the files were extracted to and double click DXSETUP.exe. This will then install the DirectX update.
If you are still getting the problem after downloading the DirectX update, I suggest that you close Video Studio, open the folder where the files were extracted to and double click DXSETUP.exe. Follow the on screen instructions until the installation is finished and then and re-start Video Studio
In my case, no reinstall of VS-X2 was needed, neither was a reboot.
I hope this helps someone
Regards
~Mike~
[color=indigo]I am only as clever as those that teach me[/color]
[color=darkblue][b]Video Studio X2 Ultimate, Video Studio 11.5 Plus[/b], Video Studio 11, [b]Video Studio 10[/b], Video Studio 6[/color]
_________________
_________________
raejohn
- ram: 2040mb
I am only as clever as those that teach me.
mikerg wrote:Hello everyone..Black Lab wrote:Did you try a re-install after updating your DirectX? Worked for me after a similar problem.
Regards
~Mike~
Hi Mike, I could kiss you!!!! I have downloaded the Direct X using your instructions. Mind you I had already gone to the trouble of uninstalling in a very scary lengthy fashion as advised by Corel and reinstalled all to no avail and now I know why..... I now am able to preview at the illustration of the remote and at other screens. I do have another problem with the multi-clip. I have imported a short dvd and I select multi-clip, it appears to work marking off the sections and allows me to preview the cut version but when I click the OK nothing happens. I am hoping that this may just be the case of a wrong preference chosen. I may, in my attempt to get the preview to work have changed one of the defaults. Any suggestion from your teacher!!
Thanks again, Rae
Re: I am only as clever as those that teach me.
Hello Rae,raejohn wrote:I have imported a short dvd and I select multi-clip, it appears to work marking off the sections and allows me to preview the cut version but when I click the OK nothing happens. I am hoping that this may just be the case of a wrong preference chosen. I may, in my attempt to get the preview to work have changed one of the defaults. Any suggestion from your teacher!!
Thanks again, Rae
I am pleased to have helped..
I have just Checked the Multi-Trim on VS-X2 and mine is the same..
I set up various Cuts and clips but neither the OK or Cancel buttons work. I think this may be a bug in VS-X2 as I have also tested it in VS-10 and VS-11.5 and it all works perfectly.
I personally don't like the multi-trim module, I get on better with using the scissors on the time-line. It is Frame accurate and less Querky than multi-trim. Once you get used to using the time-line zoom control, it becomes easy.
Maybe someone else can assist with the Non working OK and Cancel buttons in Multi-Trim
~Mike~
_________________
_________________
Hello Again..I have imported a short dvd and I select multi-clip, it appears to work marking off the sections and allows me to preview the cut version but when I click the OK nothing happens.
I believe this is a genuine bug in VS-X2.
By experimenting, I have found;-
*Press the Enter Key it will do the same as the OK Button should.
*Press the Escape Key. It will do the same as the Cancel Button should
_________________
_________________
raejohn
- ram: 2040mb
multi clip
Thanks for your imput. I have used this program before and it did work!!!
I do like to use the multi clip and have found it very useful in the past. I have sent a report to Corel so will keep you informed. I have a friend who has x2 and his also does not work. Thanks
raejohn
- ram: 2040mb
Direct X download
Hi again, I did have a question re your response and directions to load Direct X. You say double click on DXSETUP.exe mine came up as DXSETUP only - no .exe. Also there is another set up file DSETUP.dll there and I wondered if this should also have been installed. Apparently the dll stands for dynamic link library. Could you perhaps ask your learned teacher.
The DSETUP.DLL will be installed by the Install Process which happens when you double click DXSETUP(.EXE)
You will probably find that Windows has chosen to not show the extension (.exe) for DXSETUP.EXE
If, when you double click the DXSETUP file, it starts the installation process, then it IS the correct file and all other files will be installed as required by your actual system, requirements.
(If you right click on the file and select properties, it will probably show the full file title)
~Mike~
~Mike~
_________________
_________________
ABe
- Corel programs: Video Studio x5
Found this recently:
"How do you check which version of DirectX is on your system: click the Start menu, then choose Run. In the box type dxdiag and press Enter on your keyboard. A new Window will appear and your version of DirectX will be listed at the bottom."
Mine, with the latest patch, says "DirectX Version: DirectX 9.0c (4.09.0000.0904)"
Also, regarding MultiTrim, I've had the same "OK" problems. I just kept clicking and it finally worked. I'll try the "Enter" next time. Thanks.
Also, regarding MultiTrim: Is there an easy way to save all clips as separate files (without doing them one by one)?
ABe.
raejohn
- ram: 2040mb
Way to save seperate clips as files
When I have used Multiclip in the past it clips your video/movie/dvd into the number of segments you want and the small sections go straight into your time line when you click OK (that is if you are able to). I don't know why you could not click on them and save a copy. I cannot check it out for you at the moment as the OK button does not work and I only have x2 pro on my computer.
