Multi-trim turns clip black
Posted: Sat Aug 01, 2009 12:52 am
by dianebranch
Intel R Core TM2 Duo CPU T5750 @ 2.GHz 2.00GHz
4 GB 64 Bit
Motherboard: ???
Graphic Card: ???
Sound Card: ???? Realtek High Definition Audio
Processor: ???
Hard Disk Drive: ???
Memory: ????
For problems not covered, please use this format in posting your questions:
1. SUBJECT: Please use a subject that describes your exact problem
2. Describe your problem:
when I took the clip 0003.avi into the multi-trim step. Did all the trimming, pressed ok and it returned with a ¡§black picture¡¨ and no visual only audio. Don¡¦t understand VSP stuff
3. What devices are involved and their mode of connection?:
My Toshiba Computer, my video files
4. The Version of program is being used e.g. VS11+ VS11.5+ VSX2
VS 12.98.1 Pro
5. Please list all patches/updates that have been installed relating to that version of the program.
Did all of them don¡¦t remember the number but according to Sticky notes.
6. Details of the source files.
Note: to obtain all the properties of a file, right click on a video file in either the VS timeline or library window.
Here¡¦s a screen capture: http://www.screencast.com/users/AlieJam ... f8b97a8723
a. Where did they originate (camcorder, internet, TV card etc)
HD Flip Recorder
b. How did they get onto your hard drive (download, firewire, USB cable etc.) USB cable
c. Type of video e.g. MPEG2, DV, DivX, MPEG4 etc ??
d. Video data rate ??
e. Type of audio e.g. LPCM, AC3, MP3 etc??
f. Audio data rate ??
7. Project Settings
NTSC non-drop frame (30 fps)
Microsoft AVI files
24 bits, 720 x 480, 30 fps
Lower Field First
Uncompressed
PCM, 44.100 kHz, 16 Bit, Stereo
8. PAL or NTSC DVD NTSC 720x480 Stereo
9. Did this error occur at the SHARE - Create Video Step
OR have you gone directly to the SHARE - Create Disc Step
(In other words you have a VSP file in the Create Disc Step)
No Before, when I took the clip 0003.avi into the multi-trim step. Did all the trimming, pressed ok and it returned with a ¡§black picture¡¨ and no visual only audio. Don¡¦t understand VSP stuff
10. Error Codes (if any):
Posted: Sat Aug 01, 2009 1:09 am
Please use the reply button not the new topic button!
http://forum.corel.com/EN/viewtopic.php?p=183223#183223
