Saving a capture and changing presentation of the timeline.
Rollason
motherboard: Intel GM 45
processor: Intel core i3 2 duo P8400 2.2GHz 1066 MHz 3MB
ram: 3GB
Video Card: 1GB ATI Mobility Radeon HD 5650 Graphics Card
sound_card: JBL 2.1 + SRS Premium Sound
Hard_Drive_Capacity: 320GB
Post by Rollason »
I want to save a capture onto a seperate hard drive. When I attempt to do so, from the library in 'Edit mode', I find that I have saved an icon but the content is only 9kb. Obviously this is not saving the whole captured download. I guess that it's only the location and some detail on returning to the original download. How can I transfer a copy of the download to a seperate hard drive?
A further query, I want to change the presentation on the timeline to thumbnails. At the moment it shows the whole download as a (blue) constant with no picture presentation. I understand that I can change this in Preferences but on checking 'Playback Method', in Preferences, I get either 'Instant Playback' or 'High quality Playback' and no indication of how to change the timeline to thumbnail presentation.
Any help on these two questions would be appreciated.
Thank you, Roy.
Post by Black Lab »
As you have found out the library thumbnails are just that, thumbnails. They are not the actual file. You will find the actual files in the location you specified (in Preferences) as your working folder.
To change the clip display go to Preferences>General Tab and under Clip Display Mode you can choose between Thumbnail and File Name, File Name Only, or Thumbnail Only.
mitchell65
motherboard: Dell Inc. 04GJJT A00
processor: 2.80 gigahertz AMD Athlon II X4 630 Quad Core
ram: 4Gb
Video Card: ATI Radeon HD 4200
Hard_Drive_Capacity: 560Gb Sata
Post by mitchell65 »
Rollason wrote:How can I transfer a copy of the download to a seperate hard drive?
Once you have located your clip in your working folder, just drag and drop it to your other hard drive.
John Mitchell
Post by Trevor Andrew »
There is a ¡¥Smart Package¡¦ option that creates a folder containing all files used in a particular project.
This allows you to move/export the entire project.
I don¡¦t have this option (VS10) and have never used it. Others on the forum will give you more info if needed.
Your captured files should be in the Working Folder-View File--Preferences for its location.
Otherwise right click a clip and select properties, view the file name, this contains the location of the file. (click with mouse then scroll with arrow keys)
mitchell65
ram: 4Gb
Smart Package does exactly what it says on the tin. One big advantage is by using this facility you never have to "re-link" again!
John Mitchell
Rollason
ram: 3GB
Post by Rollason »
Many thanks everyone. Comments much appreciated.
Roy.
