Hi, it is possible to fix this bugs with a new patch?
sorry for my bad english
1- when in the overlay track I select a video and than I click on the button go to the end frame the current frame is wrong, if I go to the start frame no problem. This is important because if I cut without zoom in the timeline the cut is wrong
2- if I select a video in the timeline and I change the volume for example to 200% and then I split audio, volume audio is 100% maybe sw must advice when it changes my setting because if I forget to change volume to 200% editing could be wrong. If I split audio is because I wont use this audio and another video in the overlay track. A solution Could be that the sw tell us: Attention volume audio in changed! wuold you like reset volume audio to 100% or use the new setting? YES / NO
well, I'm testing X2pro trial on windows 7 and hollywoodFX Gold 4.5 work fine but only after set vista SP1 compatibility!
X2 bugs
Mmmm does not sound too PRO does it. I tried Vegas 9 last night. It left me uninspired. Corel does not really read these posts
Add your suggestions to Video Studio X2 Wish List for Future Versions
