Videostudio 11 Plus Aspect Ratio Problem
NR4P
Post by NR4P »
Purchased this last year and haven't used it much.
My problem is that when I capture a video in 16:9 mode using composite video, in the capture screen, the video fills the window 100%, corner to corner as it should. The video is 16:9 as its coming from my widescreen TV.
But when I go to the edit screen, it plays back with black bars at the bottom and top. Fills the screen left to right, but vertically compresses the video. Project playback properties are 16:9 as well.
Tried stretching it in video attributes but the lines show it as full screen already.
Post by Black Lab »
Please read Trevor's excellent tutorial on working with 16:9/widescreen.
NR4P
Post by NR4P »
That's helpful.
Apparently I did everything right.
Confusing because the capture window is 1.85:1
The edit window is apparently 2.35:1 (or thereabouts) so the top and bottom bars appear.
Did a quick test burn and the DVD was back to 1.85:1 filling the widescreen TV display.
Thank you
