am not to good with all this technical stuff .
Well, this shtuff can get complicated. and there are lots of "ifs, ands, & buts!" . So, read everything you can find, and as questions here. I typically use 3 different programs for capture, editing, DVD authoring/burning... Sometimes another program for audio editing. Then I'll use 2 or 3 more programs for the packaging artwork and labels.... And, this is ALL FOR FUN! (I'm NOT a professional.)
What is your video source?
How is it connected?
If you can't get Video Studio to work with your DV camera or capture device, you may have to use the software that came with it for the capture/transfer step. You can still use Video Studio to edit your videos.
If you are capturing analog, you must use FireWire or USB-2. (USB-1 can't handle real-time video.)
In general, you shouldn't try to capture in MPEG. You need a really fast computer to perform the real-time MPEG compressoin. And, if you're planning any editing (other than cuts & splices) the decoding & re-coding of the MPEG will cause degradation.
Your MPEG encoding should be the last step before burning to DVD. (Video Studio will do this automatically, if your're editing AVI files.)
I have VS-8 and when I've edited MPEGs it has generated slightly-corrupted MPEG files which cause DVD Workshop to crash, and Audio/Video sync problems in the finished DVDs.
