Color clips
erdna
motherboard: Gigsbyte H81M
processor: I7 4770
ram: 16GB DDR3
Video Card: Intel HD4600
sound_card: Intel display audio
Hard_Drive_Capacity: 1TB 7200rp
Monitor/Display Make & Model: Panasonic TX32cx600e
Color clips
Post by erdna »
When I use color clips from the library in a 16:9 AVCHD project, it turns out that all the clips in the library are 4:3 and can't be changed. Is this normal? Unusable for 16:9 projects?
Post by Black Lab »
Can you be more specific regarding your workflow.
With my project set to 16:9, when I drop a color clip onto the timeline it is automatically adjusted to a 16:9 aspect ratio.
erdna
processor: I7 4770
ram: 16GB DDR3
Post by erdna »
Indeed in a 16:9 project it looks as if they are converted, as well as in the resulting DVD and/or video file. Strange enough, only when I create a WVM file out of the same project, the color clips (and only the co;or clips) show up as 4:3.
Post by Black Lab »
I don't know. I dropped a color clip in the timeline, set my project for 16:9, then went to Share>Create Video File. First I chose a WMV template (HD 720 30p), then I did a second, choosing Custom>WMV, and both produced a 16:9 video file of my color clip. :roll:
Post by Trevor Andrew »
What template are you using to create the Wmv file :?:
Post by Black Lab »
And what version of VS are you using? That will have an affect on what templates are available.
erdna
processor: I7 4770
ram: 16GB DDR3
Post by erdna »
The .WMV format is HD 720 25p from an AVCHD project, straight from the original timeline (not from a reloaded AVCHD file).
My x2 pro version is 12.0.98.1 Pro
Post by Black Lab »
Maybe someone with AVCHD clips can try to replicate your problem.
erdna
processor: I7 4770
ram: 16GB DDR3
Post by erdna »
Black Lab wrote:Maybe someone with AVCHD clips can try to replicate your problem.
Indeed...
Of course a 16:9 image from Photoshop and inserted as an image solves the problem.
I have even more issues with the "straight from the timeline" stuff.
On two different occasions I got a problem when creating (burning) an SD DVD straight from the timeline containing VBR 16Mb/s AVCHD clips.
the DVD's stopped on a specific scene when played on several home DVD players (not on PC, not on a BD player). I verified the bitrates and saw they went up to 12Mb/s and at onsa specific scene up to 18Mb/s, while the max bitrate was set a 8Mb/s. Exactly the same clips resulted in a perfect SD DVD when first a (AVCHD Pal HD 1920) video file was created and from there the DVD'S. Ever seen this before?
erdna wrote:.........
This is why a work flow was devised several years ago. You will find it here:
Suggested work flow by SJJ1805 for Video Creation
