You misread my post. I said 'OK to good' only in relation to hybrid discs produced by first rendering a new AVCHD file and burning that to disc. The OK results occurred when I didn't know enough to set high quality bitrates. I was using a default VS bitrate of VBR max. 15 Mbps which averaged out at about 12 Mbps. I could fit over 50 minutes at that quality on a single layer DVD. But while the quality was clearly better than a standard definition DVD, I was not satisfied with that. When I upped the bitrate to 18 Mbps, I got the 'good' results (but only 20 minutes per DVD).
But you seem to be down-translating my use of the word 'good'. I meant good as good -- though you might need the word 'very' added to 'good' to understand what I meant. I could hardly tell the difference between my original HD footage and the edited/converted version. But when I then used the workflow of editing and jumping straight to the burning module, I got 'slightly' better results. And by that, I suppose you can bump up 'very good' to 'excellent'. I could not tell the difference between the original video and the final version on the DVD as played on my PS3 to my 46 inch true high def (1920 x 1080p) HDTV.
I guess I should get out of my British tendency to understatement...!
I should also make clear that my first few AVCHD discs were produced with VS11.5, and I had no more difficulty with that than I do with X2...
If you have a recent version of Vegas Pro (8 or the recently released 9), I think you should like the result. VS and a number of other amateur level editing programs have a number of bugs and blips when editing AVCHD, quite apart from the need for a pretty powerful computer (at least a decent Core 2 Duo) to edit it smoothly. See, for example,
http://forum.corel.com/EN/viewtopic.php?p=178901#178901 Vegas -- and even its cut down version of Movie Studio (must be the Platinum version) -- apparently uses a (Cineform) codec/plug-in which avoids these blips.
So good luck! And in any case, you are lucky in that you have alternative programs which work successfully in producing what you are after...
