svoith wrote:....
I'm thinking it would be nice to have the program and the files together on the portable drive so I can work on any Windows XP machine with a USB plug. (?) .......
Yes you can, and in fact I do this sort of thing with my laptop.
My laptop has a 160GB Hard drive, which for most people is perhaps large enough. I on the other hand have a triple boot system where on start up I can select between
XP Service pack 2 - also specially tweaked for Video Editing.
No Internet, No anti Virus and all non essential services and background stuff turned off. The only software installed is that which is needed to perform Video Editing or Photo Editing. On Start up the Windows Task Manager reports 12 running processes and very little RAM being used.
XP Service pack 3. This is my day to day operating system.
Vista Home Premium This was pre-installed when I bought the laptop. I log into it when needed to perform the odd task that Vista can do better than XP (Not very often!!)
So you can imagine that my hard drive, split into 3 partitions has already used up a lot of valuable space by supporting 3 operating systems.
Next, take a look at my signature block and you will notice I have several versions of the same software - I did this deliberately to help with troubleshooting issues on this Web Board. Again lots of hard drive space used up and I haven't even got to the stuff I actually store on the computer - such as 15,000 photographs, Word Documents, Excel spreadsheets and so on.
Furthermore, being a bit of a computerholic, I even have around 2 dozen other operating systems in the form of Virtual machines, tucked away on my trusty 1TB USB external Hard Drive, things like Ubuntu, Fedora, Suse, Mandriva, plus of course Windows 95, 98, ME, 2000 and so on.
Here is how I install software such as older versions of VideoStudio, Microsoft Office and other such things onto the external hard drive in such a fashion that it is installed "once" but can be used by any of the operating systems capable of using it.
As an example I shall install VideoStudio X2 onto the External Hard Drive from XP, and later use that installation from Vista. The procedure for plugging the external hard drive into a completely different (physical) computer is the same.
Step 1 is to make sure that all your operating systems/computers treat the external hard drive as having the same drive letter. For convenience I adopted the drive letter "M" (For MyBook - the name of that particular USB Drive manufactured by Western Digital)
If you don't know how to assign a drive letter
Click here.
Step 2. Create a Folder for your (shared) Programs to be installed into.
Normally programs install at
C:\Program Files
It is therefore sensible to create a folder of that name on your external hard drive, using my drive letter M my (shared) programs all install into
M:\Program Files
Step 3. Install VideoStudio - but when you are invited to change the installation location simply change the
C:\Program Files\....\....
to become
M:\Program Files\....\....
Therefore VideoStudio X2 will be installed at
"M:\Program Files\Corel\Corel VideoStudio 12"
Step 3.Reboot the computer but this time start up in Vista.
Or if you are using two different computers, plug your external hard drive into the other computer - think about it - it's the same thing.
Make sure that the other operating system / computer treats the external hard drive as having the same drive letter, in my case M
Step 4. Rename the Directory created at Step 3 above from
to become
X
Step 5. Install VideoStudio - but when you are invited to change the installation location simply change the
to become
VideoStudio will now be fully working in Vista (Obviously) but now it is time to see what happens when we start up XP (or plug the external drive into the original computer) - Don't forget we renamed the directory created by the other operating system and so it will now be looking at the new one created in Vista.
Once you are happy that VideoStudio still starts up with the original operating system (or computer) you can then delete the directory
x
