I had a bunch of digital pictures from my kids' school show and wanted to publish to VHS tape. So I created a project (not from a DV template) put in pictures, transitions, motion, titles, and audio music.
When I tried to export to DV tape (to later hookup to VCR to create a VHS tape), the option was not available (this wasn't a DV project remember?)
So, I exported as a DV file - a 3:30 created an almost 800MB .AVI file!
I imported this file into a DV project and when I finally exported to DV tape, there was no audio. I ended up using Microsoft's "Windows Movie Maker" to creat a project, add the .AVI, and export to tape - and it worked, no problem.
Any ideas why VS8 let me down here?
Thanks!
Rob.Mitchell@comcast.net
[Q] Sound missing on export to tape using VS8
THoff
Yup -- because you haven't updated to V8.01 yet.
You can find the V8.01 patch HERE.VideoStudio 8 Update Pack (Build Number: 8.01, Release Date: 2004/09/06)
Enhancements
Supports double layer DVD-Video import and burning
Added Undo/Redo icons on the user interface
Enhanced SmartSound Quick Track performance
Bugs Fixed
Fixed the old update pack published on 2004/8/24 can't recognize the Upgrade version while installing
Fixed the problem that the sound is gone after the DV clips are recorded back to the DV camcorder
Fixed the re-load library presets problem after daylight savings time adjustment
Fixed audio fade in/out between the transition effects, the fade out effect is gone when previewing
Fixed the program crashing problem when working in the Title stage
Fixed the problem when the program was not able to keep the capture settings
Fixed the incorrect behavior problem when more than 5 video filters are applied
