X2 and Windows 7
Rich2Putt
operating_system: Mac
processor: 2.9
ram: 8gb
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: IMac AIO
Post by Rich2Putt »
1. Download and install the Microsoft Windows Clean Up utility. This will remove all registry keys associated with the VideoStudio 12.0 install process:
http://support.microsoft.com/default.as ... -us;290301
2. Run the Windows Clean Up utility; Click Start >> Programs >> Windows Install Clean Up. Highlight VideoStudio 12.0 from the list of products. Click Remove. Click Exit when done.
If an error occurs after clicking the remove button, just click Ok to ignore and exit the utility.
3. Delete the following folders/directories:
C:\Program Files\Corel\Corel VideoStudio 12\
On Windows XP:
¡E C:\Documents and Settings\[username]\application data\Ulead Systems\Corel VideoStudio\12.0
On Windows Vista:
¡E C:\Users\[username]\AppData\Roaming\Ulead Systems\Corel VideoStudio\12.0
4. Go to C:\Program Files\InstallShield Installation Information\ and delete the {F0FDF9C9-1DDC-401F-B638-36F1CAE8A875} folder.
5. Go to Start >> Run and then type: regedit
6. Hit "OK" to launch Regedit window.
7. Go to "My Computer\HKEY_CURRENT_USER\Software\Ulead Systems\Corel VideoStudio"; delete the folder "12.0"
8. Go to "My Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Ulead Systems\Corel VideoStudio"; delete the folder "12.0"
9. Close the Regedit.
10. Clean up temporary files and Recycle Bin by launching the Disk Cleanup from Start menu >> Programs >> Accessories >> System Tools >> Disk Cleanup.
The only steps that applied to my situation was #7 & #8.
Cheers
iMac AIO (late 2012)
Windows 7 (bootcamp)
VS Pro X3
8gb RAM
1 - 1TB HD
1 - 120 SSD
1 - 2TB External HD
Panasonic DVC-30
brucefl
motherboard: I7 3770
processor: 3-4 Gig
ram: 12gb
Video Card: NT Geoforce 640
Hard_Drive_Capacity: 2 T
Corel programs: VS21 VS18thru21 and more PIX13
display settings
Post by brucefl »
Well, if I can find it again, but corel did tell me if my settings were at a certain dispaly to make sure it said small lettering. Still working on movign around 7. This would be a temporary fix till they come out with a update or patch.
Bruce
Rich2Putt
processor: 2.9
ram: 8gb
Re: display settings
Post by Rich2Putt »
brucefl wrote:Well, if I can find it again, but corel did tell me if my settings were at a certain dispaly to make sure it said small lettering. Still working on movign around 7. This would be a temporary fix till they come out with a update or patch.
Bruce
This fix for the "pan & zoom" is not temporary. I shouldn't have any issues going forward with pan & zoom.
The update/patch you are referring to is for is for other issues.
Rich
VS Pro X3
8gb RAM
1 - 1TB HD
1 - 120 SSD
1 - 2TB External HD
Panasonic DVC-30
Heesenproductions
motherboard: ASUS P5Q-EM
processor: Intel Core2 Quad Q6600 2.40 GHz
ram: 6GB
Video Card: NVIDIA GeForce 9600 GT
sound_card: Realtek High Definition Audio onboard
Hard_Drive_Capacity: 1500GB
Monitor/Display Make & Model: Philips 192E [Monitor] (18.5")
X2 and Windows 7
Post by Heesenproductions »
Hi, can anyone help with the following problem on Win 7 with VS X2:
Save as still image gives error when importing the image: "These files cannot be added to this project. These files may be of unknown file format, the computer does not have enough memory or the file is copy protected. In Corel Videostudio folder, the image file is shown without any bits and also cannot be opened.
Sony DCR-SR100E HDD Camcorder recording in SD MPEG2 VBR9100, Upper Field first, 720 x 576, 16:9, Dolby Digital 5.1 Bit rate 448kbps
Sony HDR-XR200 HDD Handycam recording HD1080 recording in AVCHD, setting up to record in SD MPEG2 VBR9100 Dolby Digital 5.1
Heesenproductions
ram: 6GB
Re: X2 and Windows 7
Heesenproductions wrote:Hi, can anyone help with the following problem on Win 7 with VS X2:
Hi, I got it fixed. Run as Administrator in the program settings in the Program Files folder.
brucefl
processor: 3-4 Gig
ram: 12gb
mp4's and windows 7
Post by brucefl »
I tried something a little different, I put a mp4 in the timeline, and went right to burn. It seemed to burn the disc, and play alright (though I haven't played the whole thing)
Then I went back into vs12, this time it played in the view screen.
But when I tried to trim or multi trim it locked up.
If I first start VS up and place a mp4, it will immediatly lock up.
I am going to try a few other files in the next few days.
Passing this along FYI, and if anyone has other suggestions (I realize I can convert the files) I am still wondering as in an earlier post if it the relationshiop between QT and VS? Just a thought. I did re-associate the exentsion with QT, but didn't make a difference. I may try uninstalling and reinstalling again. QT is up to date.
New OS are such fun :D
Bruce
alan
Post by alan »
Is it possible for Admin. to contact Corel to see if and when they might
be issuing a patch for Video Studio x2 & Windows 7?
brucefl
processor: 3-4 Gig
ram: 12gb
from corel tech support
Post by brucefl »
This is what I have received fromm Corel Tech Support
Thank you very much for your e-mail.
The VideoStudio development team is aware of this issue. They are already working on this matter.
Unfortunately, this is the only info I can tell to you at this moment.
I am going to try an .avi file sometime today see if I run into similar problems.
Bruce
aafuss
motherboard: ASUS M2N-MX
processor: AMD Sempron 3200+
ram: 1GB
Video Card: ECS GeForce 8600GT
sound_card: Creative Sound Blaster Audigy Value
Hard_Drive_Capacity: 80GB
Post by aafuss »
There is a Win 7 patch-but for the Japanese version only:
http://www.origin.corel.com/servlet/Sat ... 1854353274
No sign of a similar one for English versions.
A.A.'s Ulead/Corel software:VideoStudio X4, PhotoImpact X3, PaintShop Pro X3, PaintShop Photo Express 2010.
brucefl
processor: 3-4 Gig
ram: 12gb
strange
Post by brucefl »
That is kind of weird. I guess they use VS more there than elsewhere. Though possible most of the programmers are Japanese and probably easier to fix, then switch to other languages.
alan
Post by alan »
With ref. to link:
If you need translation go to Google translate.
I have downloaded the above patch, everything is working with Video Studio & Windows 7.
Made a short video and it works OK.
But do the buttons all show in the burning module?
dalemccl
Post by dalemccl »
Not sure whether it matters, but which version of VS did you apply the Japanese patch to? That is, which territory (U.S., Europe, etc.) and which edition (X2, X2 Pro, X2 Ultimate).
Sony XR-500V, VS Pro X2
alan
Post by alan »
_________________
As far as I am aware the buttons showed up in the burning. I did not take much notice of the buttons, only to say that when I first tried it the "Next" button did not show at all, when the patch was added I pressed the "Next" button and it went onto the "Burn" DVD process.
I live in the UK, the patch was applied to VS Pro 2.
raeburn
Post by raeburn »
aafuss wrote:There is a Win 7 patch-but for the Japanese version only:
Made a small movie, burned it, "all was right with the world." :D Everything works perfectly. I use X2 Pro US version. There are 2 patches on this page, the top one is the one for W7.
